You will attach both halyards to the stern (or up) end of the pole. The other end sits in a socket in the corner of the cockpit. I use a bunch of cleaning rags to spread the force.
I wouldn't recomend using an adjustable Spinnacker pole for the job as it is not built to take the load. It is built for compression. A dedicated gin pole would be a safer solution.
Paul C25FK Sparky 'PZ' W7JVY KFS/KTK/KLB/KOK/WNU/KPH/WCC/VAI/VAJ
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> I wouldn't recomend using an adjustable Spinnacker pole for the job as it is not built to take the load. It is built for compression. A dedicated gin pole would be a safer solution. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> The way I see Jim's rig, the only load on the pole <i>is</i> compression. The halyards are taking the vertical load from the vang.
I could also imagine a similar rig with the boom removed from the mast, the gooseneck on a pad in the cockpit corner, and the mainsheet as the lifting tackle--if the boom is long enough in that position. The halyards would be used in addition to the light-duty topping lift. Howevever, in my case, the biggest challenge may be a harness that'll hold the slippery-shaped Honda...
