 rebedding teak
rdthoms
Initially Posted - 12/08/2015 :  15:17:54  Show Profile
I've pulled all my teak off for refinishing. It appears to have been last bedded with silicone. I'm now carefully cleaning all the silicone off of the wood and boat. I'd rather avoid silicone going back. What is the best to use? I think I'm down to butyl tape (from Maine Sail) or Life Caulk.
From my understanding the butyl is the best for resilience but has no adhesive properties. The life caulk has more adhesive but not as resilient.
Any experience or suggestions?
Richard
Huntsville, AL
1984 Catalina 25 SR/FK #4309
Response Posted - 12/08/2015 :  20:37:00  Show Profile
I used Buytl tape (not from MaineSail) and I've had zero leaks. I never considered the adhesive aspect as the screws provide the necessary holding power - IMHO
I made a hole in the tape using a plastic straw - then applied the tape to the bottom of each foot.
Good luck!
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
sfsmith
Response Posted - 12/09/2015 :  07:06:09  Show Profile
I agree with OJ's post. Butyl tape is easy to work with and stays pliable for a long time. But don't make the same mistake I did a few years ago and try to use the black automotive windshield butyl tape. It's incredibly sticky and impossible to clean up. The gray kind is infinitely better for marine use.
Solomon Smith
TANGO 89/WK/TR/#5942
Petoskey, Michigan
rdthoms
Response Posted - 12/10/2015 :  13:27:39  Show Profile
I've got the butyl and may just stick with that. Not that it matters because I sail on an inland lake but I got to thinking that if the stuff hit the fan it might be nice that the sliding hatch rails and the cribboard rails were stuck to the boat just a little better than the 8 or so rather smallish wood screws. If I get scientific about it maybe I'll do a left/right A/B test!
Richard
Huntsville, AL
Akenumber
Response Posted - 12/11/2015 :  06:56:24  Show Profile
I just did the same job with butyl about 7 months ago. Pretty happy with the results. I found after the initial trimming it seemed to ooze out for a few months. I would recommend leaving it alone for a while instead of trimming it every other week. Anyone else dealt with this?
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
Response Posted - 12/11/2015 :  08:33:09  Show Profile
Forget the adhesion--the screws are what hold the wood. If you want more, you'd need 3M 5200 (polyurethane). My boat builder used it to bed my teak handrails--to I remove them, I ended up losing some gelcoat. Thanks a lot.
I use Life Caulk (polysulfide)--it sets up firmly and can be trimmed, but remains flexible and is easily removed. For plastic hardware, I use Life Seal.
Response Posted - 12/11/2015 :  10:54:45  Show Profile
There is no question that polysulfide is the gold standard. It has modest adhesion, bedding rather than gluing, making it easily removable. It is a little messy and slow setting, but you only need to do it every 15-20, even 30, years. Butyl tape is easy and clean, but isn't as durable as polysulfide. Butyl is really a very viscous fluid, fluidity varying with different formulations, and will slowly ooze, especially with movement. More viscous lasts longer but conforms less, that is why selection for properties is important. Polysulfide cures to a perfectly conformed, firm, synthetic rubber gasket. A leak in the future usually responds to a quarter turn with a screwdriver. They both work, you just pick the tradeoff. I did mine with polysulfide and will be dead by the time it needs it again.
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
Bladeswell
Response Posted - 01/06/2016 :  09:41:06  Show Profile  Visit Bladeswell's Homepage
Hello All,
Butyl tape has been used a lot in the past and for some applications still is. 3M 5200 is intended for use on, (permanent) installations. 3M 4200 is intended for use on things that you expect to have to replace or remove on occasion. If I remember right, you can sort of think of Boat Life, Life Caulk and Boat Life, Life Seal the same way, respectively.
I agree with Stinkpotter. And when I get around to rebedding mine, I will be using Boat Life, Life Caulk.
Bladeswell
Response Posted - 01/06/2016 :  09:53:21  Show Profile
In my experience, Life Seal has about the same properties as Life Caulk, except Life Seal is recommended with plastic hardware while Life Caulk is not. Life Seal is some sort of composite--partially silicone I think, but it doesn't seem to have the bad characteristics of silicone (e.g. UV degradation and difficulty of removing it entirely).
Edited by - Stinkpotter on 01/06/2016 09:55:07
