 Refinishing hatch boards
DanM
Initially Posted - 06/10/2015 :  05:27:37  Show Profile  Visit DanM's Homepage
Doing this for the second time, using Cetol again.
Found a package in my cockpit after launching. It contained a new, unfinished, port companionway rail and an unsigned note "hope you can make use of this". I hope to find that kind person and give thanks. The top third of my port rail was broken when I bought it, but still serviceable.
So now I have a new project; and a question. Should I apply Cetol to the rail "slot" or leave it unfinished?
DanM _/)
'85 C25 4870
Buffalo, NY-Pt.Abino, ON
www.buffalocanoeclub.com
Response Posted - 06/11/2015 :  08:06:41  Show Profile
I would not apply Cetol to the slot. I think Cetol against Cetol would stick a bit.
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
Response Posted - 06/11/2015 :  08:20:59  Show Profile
I would apply some wax or parrafin to the slot. On my C25, after many years, the thin fiberglass that slides in that slot eroded and because it's so thin, it was difficult to repair to it's original strength. By waxing the slot, you'll reduce friction, and prevent it from wearing down.
DanM
Response Posted - 06/11/2015 :  19:09:16  Show Profile  Visit DanM's Homepage
Thanks for the advice. Applied the third coat of Cetol today, and the boards look great. I will just wax the slot. I found info in another thread here about removing the old rail and hope that will not be too difficult.
DanM _/)
'85 C25 4870
Kim Luckner
Response Posted - 06/12/2015 :  06:13:02  Show Profile
I put 3 adhesive backed felt pads under each side of the sliding hatch. These pads ride on a raised rib of the pop top. These have been on for 2+ years and seem to have solved the problem. The pads are about 1/8 inch thick. I pretty sure I found them at HD. Lift the sliding hatch to the top of the "slot" slide the pads in from inside.
Seeadler
'79 C25 SR/FK #1432
Mentor Lagoons
DanM
Response Posted - 06/19/2015 :  12:56:56  Show Profile  Visit DanM's Homepage
Removal of the old companionway rail was fairly simple. First, the inside trim came off easily, exposing the screws for the outside rail. The screws were not too tight, but fairly long (1 3/4"), so I'm glad for the battery powered driver. The screws for the outside rail, through the fiberglass, were buried and not as long. After removing some gunk and old bedding material, I used fiberglass compound to clean the area and positioned the new rail. As expected, it was too long. Measured what needed to be trimmed off and reinstalled the old outer rail and inside trim temporarily, bringing the new rail home to cut it down and form a beveled edge, and a few coats of Cetol.
The fiberglass bulkhead has an outward curvature that must be flattened by the hatchboard rail. That made measurement for the cut tricky.
DanM _/)
'85 C25 4870
