 Cockpit Coamings
pfduffy
Initially Posted - 06/18/2015 :  11:47:51  Show Profile
So the 1984 swing keel version did not come with coaming compartments in the cockpit. Is it practical to build them? Has anyone done this on their boat?
Pat Duffy
1984 SK/SR #4113
SlĂ inte
Edited by - pfduffy on 06/18/2015 12:00:46
Response Posted - 06/18/2015 :  18:36:15  Show Profile
Can't help much, mine had them. In the short run, you could get some of the pouches with suction cups and put them where you need them. Be sure to check in the cabin behind the coamings before you do any cutting to see what clearances you have!
DavidP
Response Posted - 06/18/2015 :  18:47:06  Show Profile
Coaming compartments were an option when ordering a new boat. All the needed parts used to be available. If they still are, I think they would be fairly easy to add. I don't think the parts were specific to Catalina.
Response Posted - 06/18/2015 :  18:48:24  Show Profile
Pat,
I believe the coaming boxes were an option. CD has the trim rings. You might search for someone parting out a C25 for the boxes.
Best of luck.
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
Response Posted - 06/18/2015 :  20:02:18  Show Profile
CD used to have a pocket install kit.
hewebb
Response Posted - 06/19/2015 :  03:54:00  Show Profile
Here are two that are offered from Defender.
http://www.defender.com/product3.jsp?path=-1|7504|2290179&id=74522
http://www.defender.com/product3.jsp?path=-1|7504|2290179&id=74507
Hobie 18 Lake Worth
