Hi Can anyone tell me how thick the cabin top, by the halyard wich, is? I am putting a fairlead jam cleat for the boom vang and am planning on buying the fasteners before drilling. Thanks Jay
Jay South County RI Cat 25 SR/FK/Trad #5645 Wind Dancer
I tried to get that answer when I put in my Spinlocks. I ended up just getting some bolts around 2" and cutting them off once there in. Put acorn nuts on the ends.
The decks were laid up and a liner laid in and the widths between the liner and the deck varies.. I think it gets bigger as it goes outward to the sides of the boat. These are shots of two sides of the same cutout for my vent, just forward and port of the mast. I'll take another shot this weekend with a measure next to them. It's a common question.
I did the same as others, buy long and cut them off, but sometimes the cut is sloppy and it's hard to get the nuts started.
Ray in Atlanta, Ga. "Lee Key" '84 Catalina 25 Standard Rig / Fin Keel
Sure by putting the second nut on it does two things. One is that it gives you a guide as to where to cut and the second is that you have the perfect amount of threads left exposed for the acorn nut after you remove the nut and clean up the threads.
