 Reinforcing the pull-pull steering system
Initially Posted - 03/29/2013 :  19:45:33  Show Profile
I did not think of this idea myself, I stole it from someone else who wrote about it here awhile ago (probably Arlyn). But I was thinking about it today because I re-installed the rudder on my boat, and after doing that I always re-install the 1x3 piece of wood that I use to reinforce the steering bracket down below. In heavy weather, this reinforcement can prevent the aluminum bracket from compressing, which could cause the chain to jump a link. It's not easy to reach behind the battery and holding tank. In fact, I should have put in the battery AFTER installing the wood piece, not before.
Anyway, do any of you with the OEM pull-pull steering use something like this?
Rick S., Swarthmore, PA
PO of Take Five, 1998 Catalina 250WK #348 (relocated to Baltimore's Inner Harbor)
New owner of 2001 Catalina 34MkII #1535 Breakin' Away (at Rock Hall Landing Marina)
Response Posted - 03/30/2013 :  04:05:20  Show Profile  Visit britinusa's Homepage
Good idea, think I will copy that too.
I do put some white grease on the rudder arm pin twice a year. It seized once and bent the adjustment eyebolt, which then failed as we were maneuvering into a visiting slip!
Response Posted - 03/30/2013 :  11:48:58  Show Profile
<br />...I do put some white grease on the rudder arm pin twice a year. It seized once and bent the adjustment eyebolt, which then failed as we were maneuvering into a visiting slip!
Thanks for the tip. I'll make sure to hit that next chance I get.
Response Posted - 05/06/2013 :  16:40:49  Show Profile
I did the mod after the chain jumped a link last year in a relatively minor blow (~15 kt, as I recall).
This past weekend I singlehanded down to the Delaware Bay and found myself in pretty heavy following seas which were constantly pushing the stern to port. For over 2 hours I was constantly turning hard port, then hard starboard, to keep the boat from broaching.
I am absolutely sure that if I had not installed this piece of wood, the steering would have been jumping links like crazy, possibly to the point of losing control of the rudder. I am so glad that I put this thing in. Not a single link jumped the whole time.
Given the other recent topic, I am happy to say that no cracks appeared in the rudder either.
