We spent most of the weekend getting Sunshine launched and docked in her new home. Lots of things went right and as usual lots of things went wrong. The biggest issue we had was getting the mast raised. We had rigged a 2x4 post attached to our trailer with a winch and pully thinking that we could use one of the halyards and the winch to raise the mast. It might have worked fine if the 2x4 hadn't snapped in half. Mere inches from my face! I'm feeling really lucky right now! When I think about what would have happened if it had snapped with the mast half way up I get ill. We should have used a steel post - but that's another story.
The marina at the lake doesn't have any mast raising equipment so we were on our own. I started calling around trying to find a crane but the marina called and said they were sending someone down to help us. Long story short we ended up tying a rope around the mast above the spreaders the other end was tied to the hooks under the bumper on the front of our pickup truck. While I inched the truck backwards hubby and our helper stabilized and guided the mast into place. Once it was up hubby fastened the furler to the front and tightened all of the stays.
I've spent a lot of time looking at various mast raising systems but had never seen this. It was crazy - I was shaking like a leaf the whole time because I was certain we were going to have another disaster. But it worked and hubby said it went very easy.
Anyway I just wanted to add this to the collection of ways to raise a mast.
Wow, that sounds like a disaster closely avoided! Glad you guys are OK and no damage to the boat.
How was the 2x4 rigged? Did you use it like a king post (straight up with the line over the top)? That's what I'm envisioning when reading your description.
The PO of Knot So Fast had constructed a Gin Pole arrangement that worked fairly well. The 2x4 rig with a light trailer winch on it extends perpendicular out from the mast. First you pin the mast in the step, then the line from the trailer winch is led through a block on the end of the 2x4 to the two bow cleats to spread the load. I used the jib halyard fixed to the end of the 2x4. We have the stern end up on a trailer bow roller affixed to the end of anothe 2x4 that is bracketed to the rudder gudgeons with a 3/8" bolt. The two brackets on the roller rig are 19" spacing to match the gudgeon spacing. With the roller rig, you already start with a slight (15 degree or so) and it requires a little manual effort until you reach 45 degrees or so then the winch does it all. My only mistake is positioning the gin pole too low on the mast. Next time I'll move it about 2 more feet aft for more leverage. You can't position it too high or you will have trouble removing it. Mine uses racheting straps to attach it. I'm also going to enlarge the foot of the rig to spread the load on the mast surface. I'm sure there are some plans online.
They used a steel post, and bridles which we didn't have. I'm kicking myself because I knew better than that and should have insisted on having the right equipment. I think the idea is good but we needed to do it exactly like they did it. Well except I didn't like putting that kind of pressure on the halyard. I think a rope above the spreaders is better - at least for our tall rig. Hopefully it'll be awhile before we have to bring the mast down but I think we'll just use the truck and at least two people guiding the mast if we have to do it again. I just felt safer that way.
