Hey all, Getting ready to rebed my chainplates. Did some searching, but can't come up with a good value for the proper torque settings for the bolts that secure the chainplate to the bulkhead. Anyone know?
Wow, not sure that question has every been asked! I've never replaced chainplates - but if there are lockwashers, I would tighten the bolts/nuts until they are flat.
If you're looking for a number, I'd suggest contacting Kent Nelson at Catalina.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by OJ</i> I would tighten the bolts/nuts until they are flat. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I second that. I dont think there is some specific torqure needed. It also depends on the state of the bulkhead wood. If its rot then just tight it slightly or replace the plywood.
I think these fasteners are in shear primarily, so torque is not a major concern, if I remember correctly this is a through bolted location. As has been suggested, tight so there is no side motion is good enough, I'd recommend a thread locker (loctite) to make sure the fastener assembly stays snug. I would visually inspect the hole in the chain plate to make sure it's not oval which would suggest problems with the plate. Also look for any cracks or notches in the plate which obviously would lead to failure.
FYI fastener torque is really important for tension or compression loads on the fastener axis, less so otherwise.
Thanks for the feedback. I got around to rebedding them today. Once I actually loosened the nuts, I realized how little is actually going on with them. Pretty simple. Previous bedding was silicone, and removing it from the non-skid was by far the longest part of the job.
