I'm new here, just found the place while researching a boat I'd like to buy. My wife and I are looking at a '79 Catalina 25. The boat is in good condition for her age. Except for one issue that makes me worry... The lower leading edge of the keel looks like it has taken a rather large hit and there is what appears to be the beginning of a 'Catalina Smile'. There is a 6inch crack at the leading edge of the keel where it meets the hull. The crack is not wide, but I'm not sure how deep it is.
I'm going to have a pre-purchase marine survey done, but I don't want to count on that 100%.
What can I look for to determine if this is a serious issue? How concerned would you be?
I feel that the price is fair for the boat given the condition of the rest of the boat. I'm just worried that this could become a very large problem in the near future.
Thank you for your time and oppinions...
With a bit of luck I'll be a proper member of the community in a couple weeks.
Also, can anyone recomend a good Marine Surveyer in Ontario, east of Toronto?
Here's a picture of the keel. The damage on the lower leading edge is about as long as the green line I added. The crack is (of course) out of the picture...
As for surveys (and maybe surveyors in Canada come from a different cut) but I've heard many, many stories about surveys done in the U.S. that missed some rather obvious defects - things that a trained eye should have readily identified. I certainly would want to know all available options if the surveyor misses something that has a material negative affect on value and sea-worthiness.
Based on the picture above it looks like a well cared for boat! Good luck!
The keel and bottom look really really clean. I don't see any blisters, rust, or uneven spots. That is good. The damage on the cast iron keel itself looks very minor. You could clean it down to bare metal and fix with epoxy. The cast iron does not look cracked or anything serious. Keep in mind this is cast iron and it needs to be encapsulated with epoxy under the paint to prevent rust. Either this is a fresh water boat or that job has been done.
The "Catalina Smile" crack where the keel meets the hull is much more serious. You need to look inside the keel well in the boat and inspect the keel bolts and the floor of the keel well. Clean it spotless and look for cracks. Check the keel bolts for rust or if they are loose. Look for any sign of a leak.
I am not suggesting you bypass a surveyor, but you can check for this yourself and point out to the surveyor what you found.
If no leaks, no cracks, keel bolts are tight, floor of keel well is dry, no sign of water delamination I'd just try to tighten the keel bolts and close the "smile" or have it repaired as part of the sale.
Post some more pictures, if the boat is as clean as the bottom you could be good to go. Try to show a picture of the "smile".
Unfortunetly, I didn't take any pictures. The owner accepted our offer and we have nearly a month until closing, so I'll be sure to take a couple pictures soon.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by JimB517</i> <br />[...] You need to look inside the keel well in the boat and inspect the keel bolts and the floor of the keel well. Clean it spotless and look for cracks. Check the keel bolts for rust or if they are loose. Look for any sign of a leak.
If no leaks, no cracks, keel bolts are tight, floor of keel well is dry, no sign of water delamination I'd just try to tighten the keel bolts and close the "smile" or have it repaired as part of the sale. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I'll definetly do all of that.
The picture I posted above was taken last spring. The keel now has one very small rust bubble on the surface of the paint/epoxy near the base of the keel and a half dozen or so small rust coloured stains. But, other than that, it almost looks like a lead keel.
The rest of the boat shows it's age a bit more but from what I can tell, the owner treated it with the same care as the hull and keel.
Every early C-25 iron keel I've seen (all were salt-water boats) has had rust spots on the keel, or big stains on the attempts to coat it. Cast iron is cast iron, and coatings (epoxy, etc.) will hide the rust for a while, but it won't prevent it forever. The good news is there's a lot of cast iron there, and the rust can't be seen in the water. Also, cracks or missing pieces of iron down low are not a big deal.
The "smile" and keel bolts are another story... Most of the Catalina iron fins (pre-'83?) I've seen had some degree of smile. The iron keels were hung with mild steel bolts that are usually rusty--some to the point of having little in the way of a nut remaining. Tightening them might not be feasible. There are lots of discussions here about sistering in new bolts. The later lead keels were hung with SS bolts and heavily encapsulated to the point that there was no external joint to "smile".
