 How to Attach Asymmetrical Spinnaker?
HeelinPatrick
Initially Posted - 03/29/2010 :  13:53:45  Show Profile
It's getting warmer, so I'm thinking about soft water sailing again. I cracked a rib or two on my iceboat this year, and is about healed, so time to gear up for some Catalina sailing!
As I'm learning more, I've learned that an asym often out performs a symmetrical. At least it makes sense in that symmetrical is good for downwind, and the asym is better for more a reaching angle. But so would a tighter cut sym. We race on a pretty small lake, and hoisting and gybing the sym takes practice to be able to do it quick enough.
Anyhow, so, I was hoping to learn how you have been attaching a asym. I assume this is by tacking it just infront of the headstay. But doesn't the bow pulpit deform the sail? Does it make sense to get a shorter sail, and tack it up higher, avoiding the pulpit? Pictures would be great, as I couldn't find any when I searched the site.
Anyone have experience with tighter cut sym's? I think that would have an advantage of a heavier air sail as well, if the regular sym is too much.
Patrick Moran
1981 SR/SK w/trailer
#2303 - "Chili Mas"
Lincoln, NE
HeelinPatrick
Response Posted - 03/29/2010 :  14:29:53  Show Profile
I should have checked the gallery first thing, plenty of pictures. That clears up some things. Looks like the asym is hoisted all the way up, and the tack slides on forestay, with a tack down haul adjustment to help trim sail? I envisioned the tack being all the way at the base of the headstay.
So then I ask, I take it the asym is much easier to gybe, especially with inexperienced crew? Which performs better, is more versitile, asym, or tighter cut sym? I'm not looking to get a brand new sym, so thinking an asym is the way to go.
triley
Response Posted - 03/29/2010 :  20:23:32  Show Profile
My asymetrical is good on a truly broad reach, but the farther off the wind I get from that, the more poorly she does. Just bought a triradial with the hope that she sails better further off the wind. Probably no gain in speed, but better course made good. We'll see.
Fun messing with the two of them.
