 Stern Llight
Initially Posted - 02/12/2009 :  19:02:42  Show Profile  Visit britinusa's Homepage
Anyone know the correct replacement (WM Reference?) of the Stern Light.
Going to Miami Strictly Sail this friday (Feb 13th.) and hope to pick up an LED alternative, the original reference would be useful.
Thanks.
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Response Posted - 02/12/2009 :  19:28:48  Show Profile
Dude, the boat is in your driveway. Take the bulb out and bring it to the show.
Also, some 250's have AquaSignal and some have Hella.
Edited by - Nautiduck on 02/12/2009 19:29:26
Response Posted - 02/12/2009 :  20:20:38  Show Profile
<br />Dude, the boat is in your driveway. Take the bulb out and bring it to the show. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">LOL
Response Posted - 02/12/2009 :  21:31:35  Show Profile  Visit britinusa's Homepage
Not the 'bulb' (I know you mean 'Lamp')
Duh!
It's the housing! The outer cover of the housing broke off on our last trip. I did a temp repair using a disposable water bottle and some electrical tape!
coldducks
Response Posted - 02/13/2009 :  05:06:04  Show Profile
paul,
our bow light was broken off last year. we called catalina (not catalina direct) they sent it right out. i think it cost around 25.00.
Stu Jackson C34
Response Posted - 02/13/2009 :  14:09:10  Show Profile
If the whole thing is broken, then buy either the AS or the Hella. All you have to do is wire it up and mount it. Randy's right. And you can buy it with the LEDs installed these days.
Response Posted - 02/13/2009 :  14:29:39  Show Profile  Visit delliottg's Homepage
Paul,
Did the whole thing break off, or just the lense? You should be able to dismount the remnants (if any?) & take it to the show with you. The Hella or Aquasignal guys will be able to identify if it's theirs and help you get a new one. If not, give Catalina a call & find out which manufacturer they used on your year's boat, that should give you a leg up on what you need.
Response Posted - 02/13/2009 :  20:27:51  Show Profile  Visit britinusa's Homepage
Back from the show, foot sore from both the strictly sail and the exhibits at the Miami Beach Convention center... hundreds of vendors.
Did not see anyone selling hella light units.
Think I'm going to BOW to get a new lamp unit and then buy the lamps online.
Did get to see the new 250, I focused on the outside, Admiral Peggy on the inside.
Outside not a lot of difference from last year, but a really neat new mast gate system!
The mast gate consists of a rod with a thumbscrew bolt through it and the old threaded hole in the mast.
You unscrew the thumbscrew enough that the rod slides down below the gate.
To secure the gate, just slide the rod up and tighten up on the thumbscrew.
Very neat and simple.
