Do any of the C250 owners use a motor mount? If so... 1) what model/type do you have... likes/dislikes 2) how is it mounted to the hull 3) in combination with the motor mount would you recommend a short shaft, long shaft or extra long shaft
Henk & Johanna "Floating", a few off your "barnacles". "Someday Lady" '95 C250WB #151 ('03 - 2016) "Sea ya" 30ft Bayliner (04-2018 - 09-2018) "Mariah" '96 C250WB #191 (05-2019 - 15-05-2023) "Lady J" '00 C250WK #499 (05-2021 - 09-2022)
I have a Garelick mount. I like it. It's also mounted with 4 bolts (I think, I'm crappy about those kind of details) I have an extra long shaft Tohatsu and with the motor lifted all the way up, the propeller is still completely under water.
I really like the engine and the mount and recommend both. I mounted it so the prop is just in the water up to the cavitation plate when it's all the way up.
I do not have a motor mount. My Honda 9.9 XL shaft tilts up completely out of the water. When tilted down the prop is well underwater. For me a mount would be unnecessary.
Henk, I too do not have a mount and don't miss one. I have a Honda 8 long shaft that came with the boat. I have never had any problems re a lack of power. In all the prior discussions, don't think anyone has had or recommended short shaft. Is it time to replace one or both? Steve A
I also have no mount 1998 WB #370. I just bought a Tohatsu (Nissan) 9.8 with extra long shaft 25", electric start, tied into my pedestal for throttle and shift. It comes out of the water totally for sailing and at the dock. The narrow upper part (motor) allows for full port and starboard turning. Check it out at http://www.tohatsu.com/outboards/index.html. My previous motor was a 15" shaft Nissan 8 hp. It just did not reach far enough below the stern to get a bite in the water especially when in reverse. This one is a dream. I have pics if you want to see them
Thanks guys... David that's has got to be the best step-by-step description I've come across... thanks. BTW what is the difference between tall rig and standard on a C250??
The reason I'm considering a motor mount, even though we have a long shaft 8 hp Honda when the weather kicks up we still seem to encounter frequent cavitation especially with short steep waves and/or port side healing.
Henk, Our mast is 3' taller than yours, so we have about 30+ sqft of sail more than you do or so. When we take in our first reef, my understanding is that we have the same sail area the rest of the 250's have. The extra sail area really isn't a plus on Puget Sound, I have to bleed off wind constantly to stay as level as possible to keep Rita happy. I'm considering having a standard rig main built for the boat, or sailing with a near permanent reef tucked in.
I really like having the mount, even though I never expected to need it. We haven't had a single cavitation problem since it's been installed.
Tradewind, the benefit of a mount is getting the prop deeper into the water, less cavitation. We sail on Puget Sound, and it can get choppy. While our mount was necessary because our engine wouldn't fit in the transom, it's given us some nice side benefits like the increased depth. It's also created some problems, the engine's harder to get to, it's sort of a pain to check the oil each time before starting it, and it's moved the weight of the engine back another foot exacerbating our squatting problem, which I'm countering with lead in the bow.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I don't understand the benefits of a motor mount, can someone enlighten me? My WK with the Honda 8 seems to work fine.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Zebra, you have full turning radius now, in an earlier post about motor mounts you didn't. What did you do?
I have the Nissan 9.8 XL with tiller on the boat and it has almost no range of motion, mostly due to the tiller. Is there a kit to convert to remote or did you sell the motor and buy a remote model? Or is the Tohatsu not the exact same?
I would prefer to do whatever you did as opposed to converting my other motor.
I have a new Honda 8hp short (new style - not classic) with remote that will cost $600 to make longshaft.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by essen48183</i> <br />Zebra, you have full turning radius now, in an earlier post about motor mounts you didn't. What did you do?
I have a new Honda 8hp short (new style - not classic) with remote that will cost $600 to make longshaft. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
The new motor, 9.8 Tohatsu, when installed with the remote box or attached to the pedestal for fast/slow, forward reverse, has the tiller removed. In addition I think it is more on the forward side of the engine rather than the left side. This new motor gives me more manual or ez steer turning radius than I had with the old 8 hp Nissan that had the tiller attachment (even with tiller removed) on the left side of the motor. The new motor has a friction lever in the front to loosen or lock the motor in any turn position. With Ez Steer attached I will be able to turn both rudder and motor which will help get in and out of the tight turns of docking. I did it manually last season and it worked well, but with the attachment I wont have to take my concentration off steering. Once I install I will be glad to post pictures.
