 Engine cover
jlannutti
Initially Posted - 01/29/2009 :  09:54:31  Show Profile
Anyone have any advice regarding the re-painting of an engine cover. I have a '98 Honda 9.9 4 stroke (Old style cover). When I purchased Gracie the engine came with her and it (I'm touching wood here, runs like a top)The old paint was blistered and flaking in a few spots when I got it and has continued to deteriorate. I purchased a can of Honda Grey and a can of Honda clearcoat. I intend to order a new set of decals as well in order to get it looking original.
Here is my question. Has anyone used paint remover to get the old paint off? Will it harm the fiberglass? The old paint does not seen to come off with fine sandpaper and I don't want to go to too aggressive a paper in order to keep a high gloss, scratch free end product. I even tried a wet paper 400 grit to feather the edges of the flaked area but that was not successful and reinforced to me what I already knew...the old paint must go. Any tips?
Joe
bear
Response Posted - 01/29/2009 :  10:06:40  Show Profile
I have a "95 Honda 4 stroke and I let the condition of the exterior
cover deteriorate so it wasn't presented as an item considered for theft because how shiny it was. JMTCW
Response Posted - 01/29/2009 :  10:48:24  Show Profile
Joe,
You might consider feathering the edges and painting with a sandable automotive primer and repeating the process until you get the smoothness desired. Or you could use a gel type paint remover and pay close attention so it does not attack the fiberglass under the paint. That can be tricky but an engine cover has a relatively small amount of space so it might be doable. Good luck.
Tom Potter
Response Posted - 01/29/2009 :  16:16:24  Show Profile
I repainted the cover on an older 35 evinrude for my net boat. I sanded the cover with 360 wet and dry paper and then finished with 400. Keep the hood wet with water as you sand, this keeps the paper from stopping up. Did not remove all the old paint, just feathered out the rough spots and sprayed. Remember to do several light coats to avoid any runs.
Response Posted - 01/29/2009 :  21:36:47  Show Profile
Is it really fiberglass, or HDPE (or similar molded plastic)? If you're thinking about using a stripper, I think you should verify that.
