 Deck Connector
Initially Posted - 07/29/2008 :  17:01:45  Show Profile
I need to replace the deck connector for my mast lights. I only want to replace the male, 4-pin plug side. I can't seem to find it anywhere. Been to WM, Boater's World, Defender online. Anybody know a source? I'll buy the whole thing to just get the plug.
1999 C250 SR/WK #410
Bay Village, Ohio
Sailing Lake Erie
Don't Postpone Joy!
Response Posted - 07/29/2008 :  17:38:43  Show Profile
I just replaced mine with a new model
JohnMD
Response Posted - 07/29/2008 :  18:55:51  Show Profile
I got one from Catalina Direct.
Response Posted - 07/29/2008 :  19:30:57  Show Profile
I just got off the phone with Catalina direct. They added it to their website Electrical page while we were on the phone.
larry drake
Response Posted - 07/29/2008 :  21:08:18  Show Profile
I just replaced the male and female plugs as I was rewiring the boat. Would be glad to send the the male plug for free.
Larry Drake
Response Posted - 07/30/2008 :  10:45:32  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by larry drake</i>
<br />I just replaced the male and female plugs as I was rewiring the boat. Would be glad to send the the male plug for free.
Larry Drake
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Thanks Larry, but I ordered it last night.
Response Posted - 07/30/2008 :  11:31:21  Show Profile  Visit delliottg's Homepage
John,
You may want to reconsider. The deck connector (presuming it's the same one) are very poorly made. The little screws that you use to make the connections are too long to allow you to back them out sufficiently to get the wire into the connector, and if you take them all the way out, well, make sure you're over a nice white surface so you can find them again. I bought two of them from Fisheries here in Seattle & returned both of them. I'd sheared off two of the screws on one of them, and lost a third. When I replace my deck connector, it'll be with something far more robust that those crappy things.
Response Posted - 07/30/2008 :  11:44:26  Show Profile
David,
It's precisely those little screws that have caused my need to replace the plug. They're pretty soft so, if you overtighten by even a hair, they snap off. You're right, it's pretty cheaply made but, the current one is likely the original and has lasted 10 years. What else can you ask of a $12 part? I'm also looking to avoid taking out the old one and re-bedding a new one. If I should find that I need to do that, I'll go with a sturdier connector.
Steve Blackburn
Response Posted - 07/30/2008 :  16:13:57  Show Profile  Visit Steve Blackburn's Homepage
I guess I should post this here as well?
My connector would do the same (wiggling it would turn the lights on/off). I essentially rebuilt my deck connector. You can unscrew the connector and there are little screws holding down the open ended wires. After dismantling it (just the dangling wire connector from the mast) I cut the wires to get new fresh open ends. Re screwed the wires back in but instead of using the rubber cover, I poured fiberglass resin (with the hardener) in the hole keeping the wire tail as straight as possible by taping it down. The result is that no moisture can get in there anymore and the think is solid as a rock. I'm really glad I did this.
Very easy project. I'll take a picture tonight if I can.
SEAN
Response Posted - 07/30/2008 :  16:49:32  Show Profile
I ordered the metal one from catalina direct ,
It doesn't have a no fault style of plug , meaning it could be plugged in anyway you turn it .
you have to line up the screws on the outside .
and its smaller then the original ,so you have to drill 2 new mounting holes .
I haven't put it on yet .
Edited by - SEAN on 07/30/2008 16:55:25
Chris Z
Response Posted - 07/31/2008 :  08:20:11  Show Profile  Visit Chris Z's Homepage
This looks like a good option. I might order one, since I don't like the plastic one on my boat.
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/28141/377%20710%201622/0/Outlets%20&%20Plugs/Primary%20Search/mode%20matchallpartial/0/0?N=377%20710%201622&Ne=0&Ntt=Outlets%20&%20Plugs&Ntx=mode%20matchallpartial&page=CategoryDisplayLevel1&isLTokenURL=true&storeNum=5002&subdeptNum=9&classNum=316
Al
Response Posted - 07/31/2008 :  22:17:02  Show Profile
I like that connector, Chris. MIne is currently sealed in masking tape
awaiting inspiration to replace it. The Aqua-Signal also has 5 pins, which
I wanted since I want to add some spreader or mast-mounted deck lights.
