 GPS question
AADIVER
Initially Posted - 12/12/2007 :  12:10:52  Show Profile  Visit AADIVER's Homepage
Various makes and models of handheld GPS's agree on degrees and minutes but are way off on seconds. This becomes a problem with GPS treasure hunts especially around small areas, i.e. Two Harbors, Catalina Island. Does anyone know how to calibrate several handhelds so they all agree on the seconds? Thanks.
Frank Farmer
Long Beach, CA
aa.diver@verizon.net
http://mysite.verizon.net/aa.diver
PRETTY PENNY
'01 C-250 WK, Hull #558
Response Posted - 12/12/2007 :  12:29:45  Show Profile  Visit delliottg's Homepage
Frank,
Take all this with a grain of salt, because I only have Garmin GPS units, and Magellans, Raymarine, etc. might be slightly different. However, the abbreviations I give you should be good across the board, I think.
There are generally [url="http://en.wikipedia.org/wiki/Geographic_coordinate_system"]two to three ways[/url] for most [url="http://en.wikipedia.org/wiki/GPS"]GPS [/url]units to display coordinates:
<ul>
<li> Degrees, Minutes, Seconds, abbreviated <b><i>DMS</i></b> and generally shown on your unit as: <i><b> ddd.mm.ssss</b></i> which translates to degrees, minutes, seconds and hundredths of seconds. you'll generally have to change from the default to get this. </li>
<li>Decimal degrees, abbreviated <b><i>DD</i></b> and will be shown on your unit as: <i><b>ddd.dddd</b></i> which is just what it sound like, degrees, and ten thousandths of a degree. This is not commonly used. </li>
<li>Degrees, decimal Minutes, this is the most commonly used, and translates to degrees, minutes, ten thousandths of a minute, it's abbreviated as <b><i>DM</i></b> and will be shown on your unit as <i><b>ddd.mm.mmmm</b></i>. On my Garmins (I have three), this is the default display. </li></ul>
If you make sure that all of the participating GPS units are all on the same abbreviation, they should all display the same.
Also bear in mind that there are lots of other ways to display the coordinates, these are the most common. You should also make sure that everyone is on [url="http://en.wikipedia.org/wiki/WGS84"]WGS 84[/url] (this is the most common, and is always the default, at least in North America, other countries this may not be so). If they are not on WGS84, they have no hope of ever finding anything in your competition.
Hopefully this was helpful.
Edited by - delliottg on 12/12/2007 12:47:19
AADIVER
Response Posted - 12/12/2007 :  12:39:52  Show Profile  Visit AADIVER's Homepage
David, that sounds like our solution, we'll check it out. Thanks.
Response Posted - 12/12/2007 :  12:43:55  Show Profile  Visit delliottg's Homepage
Frank,
I edited my post to give you more information on other sites.
glivs
Response Posted - 12/12/2007 :  19:09:48  Show Profile
Frank,
David nailed the two most common "user errors", i.e. incorrect format and datum settings. Depending on your location, the latter can result in errors upwards of 100's of feet or more. In addition, there are some feature differences between models that could result in differences on the order of 10's to 100's of feet, such as WAAS capability, electronics (antenna's etc.) and software. On open waters, the software is not going to result in big differences but on land under forest canopies, in particular, it can. Another source of accuracy is the number of satellite observations used to make a position estimate. When tracking your course obviously a single observation is a single position reading. Generally models in the $200+ range allow you to average any number of observations usually resulting in notably accuracy for marking, for example, the entrance buoy to your harbor or that big rock you spotted when the water was low last season. ;)
