 Thru Hull Bedding - What to use?
mfasis
Initially Posted - 04/08/2007 :  19:02:22  Show Profile
I am just about done with my pre-launch project list. Just a few items remain including re-bedding my SR Mariner knotmeter thru-hull. I pulled it out and cleaned it up because the backing block was rotted which caused it to leak when I first splashed last season. I am a little confused as to what I should bed it with. It is a plastic fitting. I have a few types of bedding compounds on hand.
<ul><li><b>BoatLife - LifeSeal</b></li>
<li><b>BoatLife - LifeCauk</b> (not recommended for plastic)</li>
<li><b>4200</b> (not recommended for plastic)</li>
<li><b>5200</b></li>
</ul>
Of this list I would be more inclined to use 5200 but I really dont want to make this a "permanent" installation.
Does anyone have any recommendations?
Mark
Mark Britton
Huntington, NY
'82 C25 FK/SR #3202
"Good News"
Happy D
Response Posted - 04/08/2007 :  19:42:08  Show Profile
Mark,
I think I would give SR Instruments Inc. a call and ask them. That way your sure to be on the right track. Talk to the Tech Service Department.
600 Young Street
Tonawanda, NY 14150
Phone 800.654.6360
Also this might be of interest to you.
<font color="blue">As of 12/22/2006 SR Instruments will no longer be manufacturing marine instruments. We will still offer service and parts for the Mariner line. For further Information please contact us.</font id="blue">
Don't know if you want to stock up on some spare parts or not.
mfasis
Response Posted - 04/08/2007 :  20:16:53  Show Profile
Dan,
Thanks for the contact information as well as the heads up.
Mark
Response Posted - 04/08/2007 :  21:39:46  Show Profile
I like 3M 101...
Response Posted - 04/09/2007 :  11:22:38  Show Profile
I use 5200 for that type of application. Contrary to public opinion, 5200 can be removed with "anti-bond" that is available at boating stores. If you are fastening the thru hull mechanically then the bonding ability is actually not that crucial. Still, I'd go 5200.
At Ease
Response Posted - 04/09/2007 :  11:45:54  Show Profile
Boat Life, Life Seal is good stuff. FWIW, I'd never use 5200 for an application like that.
Response Posted - 04/09/2007 :  12:32:11  Show Profile
I'd go with LifeSeal for that one, too.
Stu Jackson C34
Response Posted - 04/09/2007 :  12:42:39  Show Profile
The only place for 5200 on a boat is the hull to deck joint.
Response Posted - 04/09/2007 :  12:49:03  Show Profile
I'd use 5200 to bond by keel back on, but that's about it.
I'll jump on the LifeSeal bandwagon too...
Response Posted - 04/09/2007 :  13:49:33  Show Profile
<br />...Contrary to public opinion, 5200 can be removed with "anti-bond" that is available at boating stores...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
That assumes you can remove the item that's bedded with the stuff and get the "anti-bond" onto the residue. After 10 years or so, that can be a problem.
Response Posted - 04/09/2007 :  14:11:09  Show Profile
OK, OK. I am coining a new term "bondaphobia" for you folks! The boat stores are not full of tubes of 5200 because everyone is re-bonding their keels back on.
I have used 5200 for years and have put thru hulls in and taken them back off using 5200 but I do agree there are other less bondy products that will do the job you are after.
Response Posted - 04/09/2007 :  14:18:42  Show Profile
<br />...The boat stores are not full of tubes of 5200 because everyone is re-bonding their keels back on. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
A guy at my local West store laments that the company keeps sending him cartons of 5200, and he has to keep asking customers what they're buying it for, and then recommending they buy something else! (...while his store fills up with 5200!)
John Mason
Response Posted - 04/09/2007 :  15:45:12  Show Profile
Another vote for LifeSeal, but then I use that stuff for everything.
