I own a 1980 C25 SK. For a long as I've owned the boat, raising my mainsail has been the a problem. It sticks like crazy. I have to put my foot on the bulkhead an pull with considerable force to get the sail up in proper position. I've cleaned the track multiple times, replaced the slugs with ones from CatalinaDirect. No help.
The only time I have had a problem has been when there has been considerable wind and I did not have my bow directly into the wind when raising or lowering the sail. Oftentimes I sail singlehanded and will head into the wind with the motor on and then secure the tiller to maintain that direction. Raising the sail generally goes easy for me as long as I provide enough slack in the main sheet just prior to raising the sail. But once in a while, when taking down the sail, me being on the cabin top, the bow may drift to one way or another and the sail was a bit difficult to take down but it was because the sail was filing up with air again and this happens rarely. Once I even snapped off one of the sail slugs when pulling the sail down.
Hi Scott, from your description, it sounds like you've led your lines aft to the cockpit? If so, are you talking about hoisting the whole sail from its flaked position on the boom, or are you talking about getting the last foot up? What are the wind conditions at the time? Do you have gates ovver your slot? Cheers.
Yes, I should have mentioned that I do have the lines led aft.
As a general practice, the bow of the boat is pointed dead straight into the wind when I raise the main. I singlehand 90% of the time.
The problem I'm describing is from the flaked position. I don't have a gate over the slot opening. I installed an extra stopper above the slot opening so the slugs don't slip from the mast slot.
Now that I think of it, the slugs that get caught up the most are the ones on the lower part of the sail that are installed on the "rope thingy" (don't know the proper name"). I wonder if I should add some tension to that rope as the main is going up.
As others have mentioned, my main goes right up. I too use the mast stopper like you talked about and have my lines lead aft as you do.
Once I read your post, I recalled a time or two where I really struggled to get the main up the mast. The last time I had trouble I realized that I had the two halyards (the jib and the main) twisted. I figured that was the source of the problem I had before.
Is that possibly happening to you? Do you realize this problem every time you hoist the main? Do you have a similar problem with the jib? Do you have trouble dousing the main?
Although I have had the problem to the same extent, I also recommend trying Sailkote. I used it on the slugs and mast track last year and the difference was amazing. It may not eliminate your problem, but it certainly couldn't hurt.
Does your boat have a topping lift on the boom, or lazy jack lines (to catch the sail when you drop it)? If the boom is hanging way down when you raise the sail, it might put extra load on those last few slugs. Try leaving the boom on the hook from the backstay until it is up, to see if that helps in raising. Just a thought.
Take a slug and twist it 180 degrees while still attached to the sail... so it puts a fold in the sail and put the slug back in the slot.
It will start to hoist ok but then jam tight when the luff of the sail starts to get some tension on it (the sail wants to untwist). The harder you pull, the tighter it will jam the slug in the slot. When it gets really tight, (like if you've put a winch on the halyard) pulling the sail down doesn't work either... UNTIL you completely release tension on the foot of the sail so the luff goes completely slack. Then it will come down pretty easy.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ClamBeach</i> <br />"How is a slug upside-down?" Take a slug and twist it 180 degrees while still attached to the sail... BTW.... don't ask how I know this. ;>)<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Now I know why I didn't know that!
Paul <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Paul- I believe this is thought to be not a good idea, the first time I forgot to unhook the boom from the backstay was the last . Scott- are you leaving some slack in the mainsheet and vang when you hoist? I had problems with the 3/8" slugs binding in the gate and slot so I switched to 1/2" slugs with wide shoulders. Hoisting and dropping the main is now much easier. Another problem I had was a slack halyard being blown to the front of the shrouds and binding during the hoist. That was fixed when I rigged a downhaul and kept the halyard tensioned until I was ready to hoist.
You're correct if the wind is blowing hard, if it is light and your are heading right into the wind, you can do it. That is why I asked about a toping lift or lazy jacks. Either will hold the boom higher until the sail is up. Also loosen the mainsheet as you raise it.
In regard to leaving the boom hook on, I've experienced some very stressful moment when doing that. I think I'll take one of the slugs down to west marine and see what size they are. Maybe moving to a different size might help. Although, the slugs in now were ordered from CD, so I would think they should be a good fit.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by sodonnell</i> <br /> In regard to leaving the boom hook on, I've experienced some very stressful moment when doing that. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Reminds me of one of the first times I took my boat out. We raised the sails and headed to weather. Were sailing along wonderfully. Went to fall off a bit. Let out the mainsheet and nothing. Boat heeled over more. Let out more mainsheet. Finally looked up and the boom was still attached to the pigtail.
When I was just learning how to sail on my first boat, a V25, that stinkin' pigtail caused me more grief than anything else and when I got my C25, it was the first thing to go.
