OK, total newbie question. All you Admirals, captains, and other wannabes' who know more than I do just sit tight....
On my 25' Catalina, there are two wheels/pulleys at the base of the mast on the port and starboard side - right at the base. The starboard side wheel need to be replace due to age. This right wheel at the base is where my main halyard enters the mast on its way up to the top an then back down (on the outside) and connects to the clew of the main.
Are these wheels/pulleys called "sheaves"?
S/V Prima Donna 1986, 15 HP Universal Inboard Diesel, Fixed keel, Hull # 5362
I need to replace mine too. How the heck do I get the screws to come loose? I sprayed sh_tloads of WD40 in there to hopefully get them to loosen, but nooo. Thanks.
Ah, the miracle of bi-metal corrosion. When working with sheet metal screws into aluminum I've had to grind the screw heads off with an angle grinder and work them out that way... or perhaps use a LH drill. Be sure to use Lanocote, Never-seize etc when you put it back together and the next time it might be easier.
IMHO: WD-40 doesn't make a very good penetrating oil. I use PB-Blaster, but I don't know how much good it will do on aluminum/stainless corrosion.
Try your creambrulee torch on them, it might break the corrosion bond. I replaced mine but I am a fresh water sailor. They were a little tough but a large screw driver by hand was enough for mine.
Frank, You always bring a smile to my face. anyone else might have said propane torch. But I got to recall that wonderful crunchy light caramel taste. I wish I had a torch. Maybe I can borrow one to try (after I soak it with liquid wrench and let it thoroughly evaporate). Coo !!
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ClamBeach</i> [brAh, the miracle of bi-metal corrosion. When working with sheet metal screws into aluminum I've had to grind the screw heads off with an angle grinder and work them out that way... <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"> A simpler way to eliminate the heads is to clamp a vice-grip to the handle of a screwdriver, and then use it as a crank... POP! But I like the torch idea--except I wouldn't try it <i>after </i>blasting Liquid Wrench or WD-40--you might burn up the wires inside the mast!
