 Forestay tension
americanrascal
Initially Posted - 10/01/2006 :  05:46:23  Show Profile
I'd like to properly tension my forestay. I have been using a Loos Gauge but the CDI furler prevents attachement to the stay. Any suggestions on proper technique?
Millennium Falcon
Hull 551
250 WK
Response Posted - 10/01/2006 :  07:40:28  Show Profile  Visit Arlyn Stewart's Homepage
The forestay tension is in direct relationship with the shrouds. If the shrouds are tensioned properly, then the forestay is as well.
At first thought, this may not seem true and that the forestay is in relationship to the backstay. The reasoning here is that the shrouds are aft of the mast center line and their tension is opposed by the forestay. The masthead position is adjusted not by the forestay and backstay but rather by the forestay and shrouds.
Tensioning the shrouds has the effect of firming both the shrouds and forestay while moving the masthead aft. Tensioning the forestay also tightens the shrouds but moves the masthead forward. The masthead position as well as the rig tension is set by the relationship of shroud and forestay adjustment.
The backstay on the modified B&R rig of the 250 should be thought of as redundant and not involved in the rig tension settup or masthead placement. It should be adjusted last with just enough tension to keep clear of the sail roach. Too much tension on the backstay unloads the tension balance between the forestay and shrouds leaving the shrouds to slacken and is not wanted because the raked spreaders depend upon proper shroud tension.
Edited by - Arlyn Stewart on 10/01/2006 07:53:42
americanrascal
Response Posted - 10/02/2006 :  18:36:30  Show Profile
OK then its hands off the forestay turnbuckle as the shrouds are properly tensioned and the backstay is clear of the roach.
I might make one more run around the rigging though to make sure I'm not to tight on the backstay and then recheck the shrouds once more.
Many thanks Arlyn!
Response Posted - 10/03/2006 :  08:15:43  Show Profile  Visit aeckhart's Homepage
I once read an article which expressed the opinion that over-tensioning the backstay and forstay causes excessive stress on the keel by pulling the stern and bow upward and bending the boat. The result was demonstrated in one of the Americas Cup preliminary races when a New Zealand (?) entry folded in on itself. Although much of the fault lay with the reputed fragility of Ameicas Cup racing hulls, the result is the same, it broke in half. This is not to say that it could happen to a 250 or a C25, but....... given the right set of circumstances, could it?
In my opinion, it is more important to ensure the mast is plumb athwartships, and is slightly raked fore and aft. To that end, I generally tension shrouds and stays equally about two full turns past hand-tightened once I have gotten the mast where I want it. I began doing this a few years ago when excessive stress cracks, from over-tensioning, began to appear at the cabin-deck joint adjacent to the shroud chain plates on my C25. My rig is probably more loose then most owner's, but the cracks have not gotten worse, the boat doesn't seem to handle any differently,and I have some peace of mind.
Edited by - aeckhart on 10/03/2006 08:16:59
