Here is a link to the video that I had made utilizing a forespar telescoping tiller & lock boxes on Lake Michigan. Works well on a close to beam reach, not so well on a broad reach or running unless in 10knot plus winds. I know there are alot of self steering systems out there, but in my opinion the Capri's tiller rides a little low (notwithstanding a higher rise tiller) to be viable for somehting like the Tiller-Tamer; which I think is not a stable design. I have sailed +- 5 deg on course for hours using this system in light to medium air. You be the judge. http://www.youtube.com/watch?v=IdyjAOkzkik
I used an Autohelm 2000 which was great. I added the Autohelm wind vane option too which kept the boat sailing to an apprent wind angle instead of a heading---- fantastic add-on. It stood on a hollow aluminum post (supplied by Autohelm) attached to the stern pulpit (see the other topic showing "Coquette")
The 2000 had enough grunt to handle reaching and running, however in bigger waves downwind where it needed to make bigger adjustments, it drew 4 amps/hr !! 2 solar panels on the decks sometimes gave back at least 3 amps/hr but a wind generator easily gave back 6 amps/hr during windier days when the helm was taking 4 amps.
I was not aware of the apparent wind option, here on the plains it blows hard and tends to be reasonably steady but often clocks and backs over the course of a leg, this option sounds great. I am a single handed racer when I race and have simply tied the tiller and moved quickly to set a whisker pole or try to deal with other "events". This makes an Autohelm more valuable, thanks for the tip.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by fhopper@mac.com</i> <br />I was not aware of the apparent wind option, here on the plains it blows hard and tends to be reasonably steady but often clocks and backs over the course of a leg, this option sounds great. I am a single handed racer when I race and have simply tied the tiller and moved quickly to set a whisker pole or try to deal with other "events". This makes an Autohelm more valuable, thanks for the tip. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Some events don't allow the autopilots so I also used to tie off, but I added some strong bungies in the tiller control lines so that if I needed to quickly override the tiller lines, I could simply move the tiller hard and the bungies would give me the slack without having to urgently undo the tiller control lines. Works a treat for those quick dashes to the foredeck and back again !!
It also works nicely for tacking because there is enough give in the tiller control lines to initiate the tack, and then focus on the genoa/jib. If you need to turn around from the jib sheeting task and make a quick helm adjustment, you can, and then let the bungies take over again.
I like the bungie idea for tacking a lot, being able to initiate the tack and let the bungie recenter when you are grabbing that second arm's worth of sheet getting the sail across it would help a lot. I once tried to film a single handed tack in 20 knots with only one free arm... I never showed it to anyone.
