 Where can I get a mast step
djn
Initially Posted - 04/25/2006 :  21:56:18  Show Profile
Hi All, I ordered a bunch of stuff from CD to refirb my mast but there mast step and the plate that goes under it that has the holes on the side for shives are back ordered for two to three months. Is there another source? Cheers.
Dennis
No Boat
S.E. Michigan
Happy D
Response Posted - 04/26/2006 :  06:33:03  Show Profile
Exactly what are you needing? Do you have the old one?
Response Posted - 04/26/2006 :  07:25:04  Show Profile  Visit Champipple's Homepage
They had me backordered on something and it took two weeks. Give them a call and see what the holdup is. They might just be giving you standard timeframe.
djn
Response Posted - 04/26/2006 :  07:25:28  Show Profile
Hi Dan, yes I have the old one still on the boat. It has been bent over and straighten many times (so it appears) and does not have the fore and aft bales. The one from CD is also longer and bolts throught the deck vs. wood screwing in to the support peice. Cheers.
lcharlot
Antigua and Barbuda
Response Posted - 04/27/2006 :  07:32:07  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by djn</i>
<br />... The one from CD is also longer and bolts throught the deck vs. wood screwing in to the support peice. Cheers.
Don't through-bolt your mast tabernackle! The reason that the factory uses relatively short lag screws instead of through-bolting is that if you have an accident during a mast-raising, or get dismasted somehow,and the mast falls sideways, the lag screws will simply pull out of the wood, doing only minor damage to the fiberglass. If the tabernackle is through-bolted, a falling mast will likely rip out a huge chunk of the cabin roof unless the bolts break or tear through the tabernackle itself.
Response Posted - 04/27/2006 :  10:16:43  Show Profile  Visit Frank Hopper's Homepage
<br />Hi All, I ordered a bunch of stuff from CD to refirb my mast but there mast step and the plate that goes under it that has the holes on the side for shives are back ordered for two to three months. Is there another source? Cheers.
Call Garhauer direct 909-985-9993
Call Catalina Yachts 818-884-7700
Edited by - Frank Hopper on 04/27/2006 10:17:31
Response Posted - 04/27/2006 :  10:18:34  Show Profile  Visit Frank Hopper's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by lcharlot</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by djn</i>
The 89 is through bolted from the factory.
Response Posted - 04/27/2006 :  13:53:06  Show Profile  Visit Champipple's Homepage
We pulled the tabernacle out of the deck last year through shear stupidity. Put the upper on the aft stay, didn't realize it until the mast was hanging in the air attached to the tabernacle and but not to the deck. I would tend to agree with that statement if your tabernacle isn't already through bolted.
dw
boatgt
Response Posted - 04/28/2006 :  00:23:10  Show Profile
Hey Dennis,
Check out Dwyer mast for the base plate(www.dwyermast.com in the Hardware section)You may have to drill it to fit but I ordered one from CD about a month ago and had to drill it as well. I also have a good factory mast step off my parts boat if you still need one?
Gene
djn
Response Posted - 04/28/2006 :  05:42:24  Show Profile
Thanks Gene, I could actually still use my factory step and most likely will for a while, I wanted to use the shive plate and figured I replace the step as well. Cheers.
tinob
Response Posted - 04/28/2006 :  18:52:16  Show Profile
Dennis, is this a job for the E-manufacturer that you posted earlier? Val
Carl B.
Response Posted - 04/28/2006 :  22:23:42  Show Profile
Dennis,
I have a new mast step halyard plate P/N E1884 from Catalina Direct that I would let you have for 25.00 plus shipping if you are interested? You can email me at boathefner@cox.net
Edited by - Carl B. on 04/28/2006 22:51:52
Response Posted - 04/29/2006 :  06:57:55  Show Profile  Visit aeckhart's Homepage
My 88 TR tabernackle was factory thru-bolted. Guess they decided that accidents just don't happen.
djn
Response Posted - 05/01/2006 :  15:35:44  Show Profile
Hi Carl, I just sent you an email. Thanks. Cheers.
