 What to seal tiller with?
kevinmac
Initially Posted - 04/20/2006 :  22:58:52  Show Profile
Hi folks,
I drilled a hole in my tiller tonight for a tiller extension. What material should I seal it with? I am rushed, don't have time to search, sorry if it already on the site already...
Thanks.
Kevin Mackenzie
Former Association Secretary and Commodore
"Dogs Allowed"
'06 C250WK #881
and
"Jasmine"
'01 Maine Cat 30 #34
Tom Potter
Response Posted - 04/21/2006 :  11:00:20  Show Profile
I really don't think its necessary, I doubt the screw holes were sealed where the tiller mounts to the rudder either. I didn't seal mine with anything just drilled the hole and mounted it. I do cover the tiller when not in use.
I suppose if you really wanted too, you could use a little bit of Thompson Water Seal.
Edited by - Tom Potter on 04/21/2006 11:16:27
tbader
Response Posted - 04/21/2006 :  16:02:58  Show Profile
The first time I installed the port for the tiller extension it worked its way out with all of the pulling and torquing (word?). The second time I installed it, I epoxied it into the tiller as well as screwing it in. I think that will make it less likely to become dislodged, and also - as a side benefit - will likely seal the site of the installation.
Tom
