 mast gates
AADIVER
Initially Posted - 04/16/2006 :  20:17:25  Show Profile  Visit AADIVER's Homepage
Will this work on 250's?
(quoted from http://www.geocities.com/Yosemite/2358/f_rigging_tips/f07.html}
"The original configuration for attaching the mainsail, as shown at right, has one side of the kerf (mainsail track) cut out to insert the mainsail slugs. It has a retaining pin installed across the kerf, just above the cut out, to keep the slugs on the mast. The problem with this configuration is that your slugs cannot be stowed right down on the boom nor can they be lowered to the gooseneck for a reef. There's also the potential for the mainsail to snag on the end of the protruding retaining pin, resulting in a nasty tear. OUCH! Depending on your sail cover, it might not be able to go over the high sail. See alternate solution.
SOLUTION - On Panache I created two opposing clam shell gates from sheet aluminum to accept and retain the slugs. This way the slugs can be lowered right to the boom, using the full length of the kerf down to the goose neck. The image at left shows the starboard gate. The port gate is identical. Each gate is held in place with two 3/4" long stainless steel screws threaded into the mast. My reasoning in creating two gates was to open the slot wide enough to insert the slugs without removing the screws. This way the WHOLE WORKS DOESN'T DROP OVERBOARD! The screws are not long enough to interfere with the internal halyards.
It is critical that the inside of each gate aligns PERFECTLY with the insides of the upper and lower track sides. The joint must be perfectly flush on the inside. This prevents the slugs from jamming, which will probably happen at the worst time. It takes lots of patience to bend, file and fit the gates properly.
USE - To insert the mainsail slugs, back off each screw about 1/2", spread the gates apart and then insert each slug, starting with the top one, pushing them up the mast as each is installed, and working your way down to the three bottom ones which can be pushed down. The last few are dropped down because I get tired holding the mainsail up and I don't want them popping off the mast. After all the slugs are in, snug up the screws and you are ready to hoist the mainsail. Don't strip the threads in the mast, OK!. In seven years with this system, the screws have never come loose. At any rate, the mainsail tack can now be lowered to the boom for effective reefing.
If the boom isn't already on the mast, insert the goose neck first, pushing it down on top of the stopper."
Frank Farmer
Long Beach, CA
aa.diver@verizon.net
http://mysite.verizon.net/aa.diver
PRETTY PENNY
'01 C-250 WK, Hull #558
Tom Potter
Response Posted - 04/16/2006 :  20:28:30  Show Profile
Yes Frank, they will work on the 250. I installed a set a couple months ago. You can get them at Catalina Direct, they call them [url="http://www.catalinadirect.com/index.cfm?fuseaction=product.display&Product_ID=1014"]Mastgaters[/url].
Response Posted - 04/16/2006 :  22:49:47  Show Profile
AADIVER
Response Posted - 04/16/2006 :  23:49:57  Show Profile  Visit AADIVER's Homepage
Don, that shot is your starboard gate. I assume the other gate is on the port side slot?
AADIVER
Response Posted - 04/17/2006 :  11:12:46  Show Profile  Visit AADIVER's Homepage
Just checked my slug slot. It's a single, not a double so I only need one gate. Last night I ordered from CD for a pair for 32 bucks plus shipping. I've e-mailed 'em I only need one so I hope they'll ammend the order and ship me one for less bucks.
After I ordered they called and told me they're not in stock, have to be back ordered. Also, they're only sold in pairs. Hurry up and wait time.
Edited by - AADIVER on 04/18/2006 00:11:47
