 Need help preparing Trailer
ssteakley
Initially Posted - 04/13/2004 :  21:35:06  Show Profile
I plan to trailer my boat soon. I have only loaded her once on a trailer I rented from another person. I then purchased the trailer from him later and when I took possession all of the pads had been lowered all the way down. I did not mark the post and I need some advice how high to set the aft, mid and forward pads. I have a Trail-Rite trailer. How high do I set each Pad for a Wing Keel from the top of the stationary supports to the top of the movable post? Please refer to the following pics.
Thank you!
Steve
Hey You #4455 SRFK
arlingva
Response Posted - 04/13/2004 :  22:34:51  Show Profile
Steve,
I have a trail rite. I can't get to the boat until next week. If you don't get an answer before then. I'll go measure for you.
ssteakley
Response Posted - 04/13/2004 :  23:46:29  Show Profile
Thank you Bill,
Steve
jguyot
Response Posted - 04/15/2004 :  19:47:59  Show Profile
Steve
I just measured mine and they are: Bow 3-3/4" plus 25" for the tube for a total of 28-3/4" from the trailer. Mid pads 3-1/2" plus 25" for a total of 28-1/2". Stern pads 4-1/8" plus 32" for the tube for a total of 36-1/8". Trailer & boat are a 2001.
Hope this helps........
ssteakley
Response Posted - 04/16/2004 :  18:14:03  Show Profile
JERRY THANKS!
I will set them today. I do not expect to pull her out till May but
just depends on how things & time goes,
Steve
ssteakley
Response Posted - 04/19/2004 :  19:52:08  Show Profile
Jerry, I think your Trailer must be constructed much different from mine. The all the Tubes on mine are 30" long, and I did make a few markes when I used it the one and only time. I found a trailer that appears to be a 250WK trailer just like mine and here are the Measurements: Rear 8" from the top of the tube; Mid 5" from the top of the tube; and bow 11 inches from the top of the tube.
Can anyone out there please confirm this. My trailer is a Trail-rite (pictured above) that came with my 1999 250WK...thanks!
Steve
Edited by - ssteakley on 04/19/2004 19:53:42
jguyot
Response Posted - 04/20/2004 :  09:39:49  Show Profile
Steve, they may be a little bit different. Looking closely at yours & then mine, I noticed that on mine it looks as if the "wing" sits on the trailer a little bit lower to the ground. This may account for the height difference.
Edited by - jguyot on 04/20/2004 09:44:44
