What you are seeing is the cover. The cover lifts up and the turnbuckle with cotter pins is under it. I like them they work well for me. I don't know if they will work for a C25. I guess if the dealer says they are ok I would use them.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>what is this 250 mast slot for? It is very low and does not seem to be used.<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
That is where the temporary baby stays for the mast raising system hooks into. If you look on the first picture you will see on the lifeline stanchion to the right of the turnbuckles you were asking about there is an attachment loop that is where the other end of the baby stay hooks to. Once the mast is up they are removed.
Bryan is right, these turn buckles work very well. They are bronze and strong. The cover slides over to protect from dirt and grime that will foul the threads on an open design as well as protect the cotter pins.
Note the open barrel which has a more open width on the facing side which allows needle nose pliers to deal with the cotter pins... the opposited side has a more constricted barrel that allows the cotter pin head to lock the barrel.
I've heard numerous complaints about locking nuts and stripped threads on traditional turnbuckles and experienced them on my C22... These are much better.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> You can get these direct from the manufacturer for a lot less . . . Garhaurer Marine . . . and they do look very nice and work very well on the C-25. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
