 Companionway ladder prop
Timkro
Initially Posted - 07/18/2023 :  13:44:06  Show Profile
Hi All:
I've just acquired a 2001 250WK. The companionway ladder is hinged and pushes up nicely to the overhead. Is there a way to prop it?
Tim Kromholtz, Bayview, ID
2001 Catalina 250WK 2023
1978 Ranger 20 2005-2023
DavidCrosby
Response Posted - 07/18/2023 :  16:14:29  Show Profile  Visit DavidCrosby's Homepage
I cut a dowel rod to the appropriate length and wedge it into place. The pop top portion of the hatch has to be up for this to work.
I also drilled out the threads on the mounting brackets and replaced the machine screws with quick release pins. So, I can easily remove the entire ladder and set it out of the way.
David Crosby "Small World"
'02 C250 WK #614
Timkro
Response Posted - 07/19/2023 :  13:50:37  Show Profile
Good ideas. Great information, thank you!
rhs944
Response Posted - 07/23/2023 :  12:42:25  Show Profile
Agreed, nice solutions
Rick 1999 C250 WK, Cape Cod
csmcg
Response Posted - 10/10/2023 :  11:06:44  Show Profile
We keep our extendable boat-hook on clips on the outer wall of the head just portside of the steps. When we prop the steps up, we use the boat hook and set the length as needed. Works great and doesn't require an additional piece of gear.
Quick release pins sounds very handy. Thanks for the ideas folks.
Regards, Chris.
