Hi there. I saw a few of these topics were made but they're pretty old so figured I'd post my own. :) One of my pumps is nonfunctional and I went ahead and ordered the replacement and then found out it WAS possible to get the repair kit somewhat near me.
I'm probably going to order that as well and see if I can make the previous faucet a spare, but my question is: has anyone done the repair? What does it entail and what problems did you run into, if any? I took it apart and I can't see anything clearly wrong or missing, apart from obviously quite aged seals.
@ Qorqyle - I also rebuilt my Whale faucet and replaced the seals. But before I ordered the rebuild kit, I tried smearing some Vaseline petroleum jelly on the rubber parts and it worked for a few days. Apparently, it’s the vacuum and the suction created by the fresh seals (or lube in my example) that makes the pump work. I’d think that the mechanism will continue working virtually forever provided you continue to replace the seals every decade or so.
I still have 2 functioning pumps if you are interested. Check the Swap Meet forum.
I am so sorry to have not noticed that; I jumped the gun and ordered all the things. :( Thanks for the offer, I'm sure someone will want them!
quote:Apparently, it’s the vacuum and the suction created by the fresh seals (or lube in my example) that makes the pump work. I’d think that the mechanism will continue working virtually forever provided you continue to replace the seals every decade or so.
I bet you're right. I was scared away by the PO's "oh I tried to fix it once" but should've done my own research first.
Not sure if you have done your repair yet, but I replaced all the seals in a flipper pump of my own last night, and it was fairly easy. Not too much to it. Hardest thing to replace was the flat rubber piece in the bottom.
Yes, I replaced it. It was the culmination of replacing all of the freshwater plumbing so it of course took longer than expected but everything is fully functional now.
The faulty one is on the workbench awaiting some workshop time.
