 Catalina Direct lifelines
C25BC
Initially Posted - 05/18/2022 :  14:41:09  Show Profile
I just received my new lifeline kit from
CD . I Will be installing this weekend.
Any tips from anyone who has dealt with them in the past ?
Angus
S.V.Tempus
#4748
1984 Catalina 25 SK/SR/Trad.
DavidCrosby
Response Posted - 05/19/2022 :  12:24:31  Show Profile  Visit DavidCrosby's Homepage
My # 1 tip. Do not assume that the boat is symmetrical.
Do each section independently.
I assumed and when I put my C250 away for the winter, I removed the lifelines from just the port side of the boat and built two identical sets. I ended up about 1.5 inches short on the starboard side.
David Crosby "Small World"
'02 C250 WK #614
Response Posted - 05/19/2022 :  15:09:40  Show Profile
So . . . . it sounds sorta like when laying a slate patio: all the parts will fit but just not quite where you think they Will! As I recall, the opening gates are where the adjustments can most easily be made. But I agree, lay things out first, then measure, then measure again, then attach!
Peter Bigelow
C-25 TR/FK #2092 Limerick
Rowayton, Ct
cudamank
Response Posted - 05/19/2022 :  16:07:08  Show Profile
when did you order them and which kit. I checked the deluxe today and it says out of stock do to supply chain issues.
1982 Catalina 25 SR FK
"Jenny"
C25BC
Response Posted - 05/21/2022 :  11:42:11  Show Profile
I ordered them about 2 weeks ago , the deluxe uncoated ones, the guy at cd said it was the last set at the time .
Angus
S.V.Tempus
#4748
Response Posted - 05/21/2022 :  14:23:51  Show Profile
Your timing was perfect!
Peter Bigelow
Rowayton, Ct
DavidCrosby
Response Posted - 05/21/2022 :  14:47:33  Show Profile  Visit DavidCrosby's Homepage
I bought mine through Defender Marine. On the C250 Specific Forum I wrote up my lifeline replacement and it has a parts list. I am sure it could be modified to get you the right parts for a Catalina 25.
http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=32300
'02 C250 WK #614
