 Need Motor bracket for 9.8 HPTohatsu
Enchantment II
Initially Posted - 05/02/2022 :  18:47:59  Show Profile
My Tohatsu is a 9.8 hp 4 Stroke with E-start. Believe it weighs 110 lbs. I need a heavy duty bracket that can lift the motor out of the water. I have researched brackets from Garelick and Panther.: any opinion on these Brackets?
Joseph Henderson
82-CAT 25 TR SK
Response Posted - 05/02/2022 :  22:21:38  Show Profile
Here's one thread from a quick Search. The Garhauer mentioned is an updated version of the original stainless steel bracket on most C-25s, and fits the same bolt holes. Vertical travel is among the best. Pick the number of springs for the weight. You can see it on the Catalina Direct site.
Enchantment II
Response Posted - 05/03/2022 :  12:04:39  Show Profile
Thanks Dave!
Joseph Henderson
82-CAT 25 TR SK
Response Posted - 05/03/2022 :  15:38:46  Show Profile
I have the same 9.8 Tohatsu. The 4 spring Garhauer from CD is what I have and works perfectly. You will need the 16 3/4" of travel( up and down) that these mounts have.
Edited by - islander on 05/03/2022 16:31:20
Response Posted - 05/06/2022 :  11:05:39  Show Profile
Ditto -- same engine and the CD 4 spring is the way to go.
Peter Bigelow
C-25 TR/FK #2092 Limerick
Rowayton, Ct
