 c25 new look sugar scoop
cuetecpool
Initially Posted - 02/20/2020 :  22:08:52  Show Profile
Do you know of any Catalina 25 owner that has the designs for a sugar scoop. I found one in Czek republic no luck to communicating with him. Please advise
James A. Bogner CPA Rear commadore
Response Posted - 02/21/2020 :  07:31:21  Show Profile
That would be the one discussed in this thread. Tomas still posts here from time to time...
Russ.Johnson
Commodore
Response Posted - 02/21/2020 :  13:50:49  Show Profile
Dave,
Thanks for the post.
Here's a link to his personal website.
http://www.kruska.cz/C25_High_Anxiety/listing.php
I downloaded a few photos.
Notice the inboard and saildrive.
Russ Johnson
2005 C250WB Hull 793
Edited by - Russ.Johnson on 02/21/2020 13:52:13
Response Posted - 02/21/2020 :  15:02:29  Show Profile
...plus the built-in rudder post and radar arch(?) It seems to me that investment would have been better put into a C-270. (After all is said and done, in the USA, a '78 C-25 is a '78 C-25.)
Edited by - Stinkpotter on 02/21/2020 15:06:46
Response Posted - 02/21/2020 :  17:54:47  Show Profile
Or just get a Catalina Capri 26 and save yourself a whole bunch of work.
SKS
Response Posted - 02/23/2020 :  09:37:50  Show Profile
That sugar scoop modification sure looks nice.
I'm just wondering, if it doesn't change the length at the waterline, and if it doesn't add room to the cockpit, is there another advantage beside appearance ?
Response Posted - 02/23/2020 :  10:38:24  Show Profile
Some people think it's easier to board them after a swim. The main benefit I see is the inboard rudder. A boat with a transom hung rudder is somewhat more prone to broaching when the boat heels to an extreme angle and the rudder lifts out of the water. IMO, the inboard rudder on High Anxiety could have been made a little deeper for that reason, just a little shallower than the depth of the keel.
Response Posted - 02/26/2020 :  20:17:14  Show Profile
I remember his posts, spent a bundle of money in it. cute kid, too. Later, he sold it and bought a new boat, a Phobos 21, made there.
DavidP
Response Posted - 02/26/2020 :  21:01:37  Show Profile
Note that the rudder is still effectively on the original transom, so this probably doesn't help much. Generally, "sugar scoops" are part of a combination of an open transom for easy access to a swim platform and/or dingy boarding. In some cases, the transom can be closed, but is easily opened. I don't see that here.
Response Posted - 02/27/2020 :  11:38:50  Show Profile
Originally posted by Stinkpotter: Note that the rudder is still effectively on the original transom....
It's always hard to tell from a photo, but it appears that the original transom is still there, and that the sugar scoop was added to it. The rudder post is now inboard, inside the cockpit, so it's moved probably 6-10" forward of it's original location, possibly a little more. A few inches of the original skeg must have been removed to allow room for the rudder post to be moved forward, into the cockpit. If the inboard rudder had been made nearly as deep as the keel, it's hard to imagine that the boat would have broached unless the keel itself lifted clear of the water.
Another difference that the modification would have made is that, moving the rudder post forward would shorten the distance from the CLR to the rudder post, and that would enable the boat to turn more quickly. If you compare the steering of a C27, with it's inboard rudder, and a C25, you'll see that the C27 can turn in a much tighter radius and is more responsive to the helm.
