 new stove
RichardG
Initially Posted - 09/25/2019 :  16:07:45  Show Profile
After all these years milking all possible use out of my ever-finicky curtain burner, I decided to go for an upgrade. I often make coffee while heading out, and sometimes cook under way, so I also wanted to maintain the gimballing of the original stove. This is what I came up with...
Took apart the original--
Saved the heavy bar, cut the stainless tabs and drilled 4 mounting holes (by far the hardest part of the project) --
Cut and mounted aluminum bar --
Got a $20 cheapo stove from the Asian market, drilled holes in the bottom and mounted it to the aluminum bar. And with the cutoff, I also fashioned and mounted a 'sea rail', which to mount pot holders --
Mounted the whole thing back in --
And made a cup of coffee --
Then put the cutting board back in. For safety, I store the fuel bottles in the little aft portside locker --
RichardG 81 FK/SR #2657
Terminal Island, CA
TCurran
Response Posted - 09/25/2019 :  16:22:56  Show Profile
Looks great
Tom Curran
1981 Capri 25 Hull #101 "Dirty Debbie"
1988 Watkins 30
PAFB, FL
Response Posted - 09/26/2019 :  03:45:46  Show Profile
Love it, Taking something old and making it functional again. Thumbs up!
Response Posted - 09/26/2019 :  13:24:02  Show Profile
Wow! You da man!
