 Batten Pocket with a strap no velcro
vdotmatrix
Initially Posted - 02/02/2019 :  18:22:31  Show Profile
On our catalina sails we have batten pockets with stout velcro closures.
On the capri 25's main we have a nylon strap that you must thread to trap the batten in place....Does anyone know the name for such a setup?
Response Posted - 02/03/2019 :  09:18:34  Show Profile
"Old school".
PO of 1985 C-25 SR/FK #5032 Passage before going over to the Dark Side (2007-2025); now boatless for the first time since 1970 (on a Sunfish).
Response Posted - 02/03/2019 :  10:34:44  Show Profile
I can't visualize the arrangement from your description. I'm familiar with four methods for securing battens. By the older method, the batten was slipped into the pocket. It had a flap of sailcloth over the leech end of the pocket. By bending the batten, you could put the leech end of the batten behind that flap of sailcloth, and that held it in place. I have heard this called a standard or traditional batten pocket.
After velcro was invented, some sailmakers put a flap of velcro over the end of the batten pocket to hold the batten in place. The other piece of velcro was sewed to the outside of the batten pocket. I haven't seen this often and don't know of a name for it.
Later, North made the flap of velcro much longer and sewed the other piece of velcro inside the batten pocket. You used a special tool to push the long velcro flap into the batten pocket, a string was used to remove it. Now that I think about it, I can guess that your mainsail might be a North sail, using this method. North calls it a velcro stuff batten pocket. Here's a link. https://www.northsails.com/sailing/en/2018/06/velcro-stuff-batten-pocket-installation-guide
Some sailmakers use a mechanical system for their sails. A device is attached to the luff of the sail at each batten pocket. Each batten has a hole drilled through the luff end of the batten. Then a threaded screw-like thing goes through the hole and is screwed into the device that is attached to the luff. I think this is called a captive batten system.
Edited by - Steve Milby on 02/03/2019 10:41:08
Peregrine
Response Posted - 02/03/2019 :  15:42:24  Show Profile  Visit Peregrine's Homepage
A photo or two would help to make this more clear.
Is it a partial or full batten main?
I'm not sure there is a specific name for the batten securing method your mainsail maker used.
John Gisondi
Peregrine
#4762
vdotmatrix
Response Posted - 02/03/2019 :  17:14:28  Show Profile
https://www.amazon.com/photos/shared/sLdCfpVhRxei3NMcjC3-0w.92WJCzxDTtYcApLFyAG3mx
hope you can see this. we got it on the boat today.
Response Posted - 02/03/2019 :  18:26:28  Show Profile
I've never seen one like that. Who is the sailmaker?
Peregrine
Response Posted - 02/04/2019 :  09:27:56  Show Profile  Visit Peregrine's Homepage
Well it certainly locks the batten in place.
John Gisondi
Peregrine
#4762
Response Posted - 02/04/2019 :  09:59:18  Show Profile
It certainly does. Hefty piece of hardware.
Response Posted - 02/04/2019 :  10:43:28  Show Profile
I'm trying to figure out how it works. Is one end of the woven strap attached to the luff, and then routed inside the batten pocket to the leech, and then around the leech end of the batten, then inside the batten pocket to the luff, and then through the tensioner? If so, compare it to the captive batten system, which is simpler and probably more secure.
Here's a photo of the captive batten system. The main difference is that it eliminates the long woven strap, which adds weight aloft to the system, which would be a disadvantage in light air. As you can see, the batten fits into the slider and it's captured in there somehow. The brand I have used is a Selden, probably 25 years old, and there's a screw that holds the batten in the slide.
Edited by - Steve Milby on 02/04/2019 10:51:51
kjk
Response Posted - 02/05/2019 :  07:33:01  Show Profile
...because battens don't float...:(
Kevin J. Kiely
Rockport, MA
1999WK
Hull # 407
dasreboot
Response Posted - 02/06/2019 :  10:09:41  Show Profile  Visit dasreboot's Homepage
I would think that is made that way to adjust batten tension. As there is no need otherwise for such a complicated system at the luff edge otherwise. All that is really needed is a plastic pocket to hold the batten end.
Todd Lewis
Eowyn 87 TR/WK C25 #5656
ARWEN 84 TR/SK C25 #4031
www.mainsailsailingschool.com
