 Dinette table pins
Erik Cornelison
Initially Posted - 06/12/2018 :  14:29:38  Show Profile
Are there pins that lock the table to the wall? If so I need some.
Table works almost as intended, holds plates and cups while eating. Problem is if someone puts weight on a side it pops out of the brackets. Doesn’t take much for the table to twist out.
Erik Cornelison
1986 Standard Rig SW. #5234
Response Posted - 06/12/2018 :  19:43:55  Show Profile
Erik,
Sorry, which cabin layout do you have? Port and starboard settee with the swing-down table attached to the port side bulkhead? Or the dinette style cabin with a starboard settee with a pair of opposing seats on the port side with a dinettetable in between?
If the former, some people have replaced the brackets with hinges. If the latter, there should be two rubber hold-down straps that keep the table securely held in place. You can purchase them from Catalina Direct.
Here is a link to the part I’m familiar with:
https://www.catalinadirect.com/index.cfm/product/2921_31/soft-latch-flexible-coverbr-draw-latch-bent-catch.cfm
If you need some hinges, look for some quality brass or stainless steel hinges.
Edited by - Voyager on 06/13/2018 03:46:33
Erik Cornelison
Response Posted - 06/13/2018 :  10:00:13  Show Profile
Bruce -
I have the latter - I see the rubber hold down straps available..thanks..that should work.
Erik
Erik Cornelison
Response Posted - 06/13/2018 :  11:17:23  Show Profile
I drilled holes through the bulkhead and use aircraft lock pins. OOPS, NEVER MIND, I just saw the last post. I did not realize they still had the dinette in '86.
I hated the factory table so I made several small ones with the same hardware so my pins would work with any table.
Edited by - pastmember on 06/13/2018 11:32:02
