 Running lights blow fuse
slim
Initially Posted - 03/02/2016 :  16:46:15  Show Profile
Here is one for the books! You just never know what kind of mischief the PO’s have done to your boat. My running lights when turned on would burn out the fuse in less than a minute and i spent a lot of time chasing down the problem by tracing the wiring all the way from my new electric panel forward and aft. As it turned out when i pulled the forward fixtures off of the boat and removed the bulbs i found that one of the bulbs had been replaced with a single pole bulb like you would use on a auto and the ground was due to that bulb. Once i replaced it with a double pole light i did not have the ground any longer and my lights work perfectly. Of Course all the seals and gaskets on the lights were trash and i am replacing them with butyl tape but i did not have to replace my wiring the old stuff is still good.
Single an double
1978 - C25 - standard rig - Fixed keel #1040
Response Posted - 03/02/2016 :  19:59:51  Show Profile
Good catch! In other words, the single, centered contact on that bulb contacted both the + and - terminals in the base of the socket, creating a direct short from + to - without going through the filament. Fortunately, the short was strong enough to blow the fuse before a fire started, because it could have.
Response Posted - 03/02/2016 :  20:50:32  Show Profile
Originally posted by Stinkpotter
Good catch!
I thought so, too. I probably would have replaced the fixtures and wiring and fuses and master panel, and never noticed that there was one contact on the bulb and two in the fixture!
Response Posted - 03/03/2016 :  07:34:25  Show Profile
I'm always amazed at what dumb things PO's do. Never bothered or didn't even know to see if It was a single or dual contact bulb. Hey It looks the same so....
Response Posted - 03/04/2016 :  12:36:18  Show Profile
Sometimes we jury rig something in an urgent situation and forget to correct it later; of course regularly blowing fuses seems like it might be a reminder.
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
Response Posted - 03/04/2016 :  16:02:15  Show Profile
Slim,
The smaller bulb that is supplied with the hull mounted lights draws about .7A and, I always felt, is barely visible even at night. The last time I replaced mine I used one of similar size as the single contact light (BA15s) you show in your picture but with dual contacts. (BA15d) These draw about 1A each but are significantly brighter. The fuse in my fuse panel was a 3A fuse which was sufficient for two of the .7A bulbs and my stern light. However when I used the higher current bulbs it was not which I found out the hard way about 4:00 AM one morning. I replaced the 3A fuse with a 5A fuse and it has worked fine since. The larger current bulbs are a nice and inexpensive upgrade.
http://www.bulbs.com/product/1004?RefId=567
Joe Wergers
Utopia
Fleet 7/Oceanside, CA
78 C25 FK/SR #381
SKS
Response Posted - 03/06/2016 :  13:16:13  Show Profile
Why not go with LED bulbs ?
They are brighter , use less power and last far longer.
I think I'll be changing out all the lights on my boat this season with LEDs. Especially the inside lights. The fixtures are obsolete. Although most of them work, the bulbs have rusted in place and can't be replaced if they burn out.
I'll be replacing the bulbs in the running lights with LEDs as well. This was imperative in my old Catalina 22 because I had no way of charging the battery once I left the dockside power source. My Cat 25 has an inboard diesel and dual batteries, so I can charge the batteries underway, but still, using less juice is important.
Response Posted - 03/06/2016 :  16:02:03  Show Profile
Keep in mind the LEDs put out a very narrow spectrum of light and a white LED behind a red or green lens may well not meet range requirements. CG certification is for a light+housing assembly.
