Purchased aftermarket plastic lenses for the tow vehicle and one of them filled with water - while sitting parked in the rain. Need to caulk seam where front and rear halves join.
Has anyone researched caulking that is safe for plastic? I'm thinking I might just push butyl tape into it . . .
Had the same problem with one of my headlights. Kept getting moisture inside. I pulled the bulb out of the back and pointed a hairdrier into the shell to dry it out then ran some BOATLIFE Life Seal (good for plastics and is clear) that I had around the seam where the front joins to the back and the lens has stayed dry and clear ever since. That was over 3ys ago.
Second the Life Seal--it's a urethane-silicone hybrid that's specifically compatible with plastics and has worked well for me. WM and others should have it.
Might work but what happens to that tape when the light gets it hot...Does it melt, Soft and runny/gooey?
Excellent point Scott, thx.
Here's the video that introduced the Dupont acrylic silicone (the guy is pretty long winded . . . he talks about the product at the 8:50 mark.) A Mercedes Benz with moisture in the headlight!
