The original Spreader Boots on JD were Canvas Pads with Black Webbing to secure them to the Spreaders. The Shrouds had to be wired in to the ends of the spreaders. They lasted 6 years and then deteriorated a bit. While at West Marine, I saw the spreader boots that are molded plastic that hold the shroud in place, the boots are secured in place with tie wraps. [url="http://www.westmarine.com/webapp/wcs/stores/servlet/Product2_11151_10001_99187_-1____ProductDisplayErrorView#.UNcmYm9X2NA"]Plastic Spreader Boots - thumbs down[/url]
After one year of use, they are a disgrace, split, worn, dirty and basically falling apart.
I installed the Taylor made a year ago and they are holding up well, however I did notice that there were burned marks on them and I assume the marks were from the 150 sliding on them. I ordered rollers and installed them on the shrouds during the recent up grade activities. I hope they will help the life if the spreader boots and sail.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by britinusa</i> <br />While at West Marine, I saw the spreader boots that are molded plastic that hold the shroud in place, the boots are secured in place with tie wraps.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I've used the rubber/plastic boots, and they've lasted a number of years (with occasional re-taping), but I never considered them an alternative to wiring the shrouds to the spreaders, if that's what you meant.
The plastic molded type do a pretty good job of holding the shroud into the groove at the end of the spreader so I did not use the wire. However the Taylor made version really does need them wired in.
I'm guessing that the plastic molded type just don't seem to be able to handle the Florida Sun.
I use the Taylors on top of the stanchions that people put their hand on when getting on the boat, I use the rubber boots with swage wire on the spreaders. Rollers at the spreader are always a nice ad on.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by britinusa</i> <br />The plastic molded type do a <i><b>pretty good</b></i> job of holding the shroud into the groove at the end of the spreader so I did not use the wire... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Hmmmmm... The cover will allow the shroud to go right to the end of the slot, if not beyond it. If by some chance a shroud goes slack as the boat is pitching and the "pretty good" isn't quite good enough, and the cover hides the fact that the shroud is no longer secured, your mast could come down. (It's the same thing as a broken spreader, and it happens.) I'd recommend seizing wire, regardless of the cover. (I happen to have more than a lifetime supply, and no sailboat. )
Agreed Dave, even though the plastic boot seemed to keep the shroud in place even when the mast was down, the siezing wire takes out the risk. I now have a reel of SS siezing wire from harbour freight the only cost a rew bucks. There's enough wire to last a couple of boat lifes.
I was surprised to find that the PO of Iris had used hardware store steel wire for seizing wire, adn it had rusted through. This is one spot where I would really recommend stainless, marine grade stuff.
The job is simple and takes little time if you already have the mast down for winter storage (or to replace the spreader boots)
The only challenge with this job is getting the right tension on the shroud. You need it loose enough for teh shroud to travel freely in the groove, but tight enough that it can't slip out.
