OK Gentelmen and Ladies... How much of a pain in the a.. is it to dropping the mast? I have had my 250 for 8 years and never once have i done it...my boat sits in the columbia river year around, i dont own a trailer, and i have things that i want to add (uhf antenna, wind vane, led light mast light). I dont have a bosans chair or mastmate ladder either... Plus,I have a Roller Main Sail and would be doing it solo!! Sugestions Please!! thanks
Just saw the other thread about mast raising as well...
Steve Pipoly 96 Catalina 250 #231 WB/SR/SK RCYC Portland Oregon
Because you asked, says you shouldn't do it by yourself but that you should have an experienced person assisting and directing. Without a mast raising system... in my opinion three strong men are needed and again... one of them should be experienced in doing it.
You could construct an A Frame and do it yourself but I'd suggest at the minimum that you assist another lowering and raising first. There is simply too much risk of injury or damage to wing it.
Can't help but be straight and direct on this one.
Have been having the same nightmares regarding lowering the mast as I sail shorthanded, after much research I found a guy here in Australia that manufactures mast skates. There are numerous mast lowering systems but I felt that this one suits me for ease of use and safety.
This way it runs up the mast groove attached to two poles via articulated elbows that are attached to your jib tracks and you lower from the cockpit. The poles act like a mast crutch therefore very secure and safe.
Unsure if there is a manufacturer from the other side of the pond that has similar systems, but it may be worth looking into.
Hi Steve, I also have a '96 WB which originally came with a gin pole mast raising system and has a recepticle at the base of the mast that is designed to accept the pole. The gin pole also has a small trailer like winch attached that allows the mast to be raised and lowered easily by one person.
I used this system for several years until I modified my trailer to be used as part of the mast raising system similar to the newer 250's. I have kept the gin pole system however to use under special circumstances such as low bridges and some marina facilities which have sling launchers that require the mast to be down until you are on the water. This is the case at Anacortes WA to enable the use of the smaller sling which is considerably less expensive to use than the larger "mast up" sling.
You would be welcome to use my gin pole if you were closer to Lake Tahoe or if you were coming this way.
I also have a new "Mastmate" climber which I bought for my Hunter and never used. I was just going through my garage "chandlery" and spied this item and am considering selling it back to the company unless there is someone out there that would like to buy it.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Skipper Paul</i> <br />Hi Steve, I also have a '96 WB which originally came with a gin pole mast raising system and has a recepticle at the base of the mast that is designed to accept the pole. The gin pole also has a small trailer like winch attached that allows the mast to be raised and lowered easily by one person.
I also have a new "Mastmate" climber which I bought for my Hunter and never used. I was just going through my garage "chandlery" and spied this item and am considering selling it back to the company unless there is someone out there that would like to buy it. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> How much do you want for the Mastmate?
