Mine ended up at the bottom user day. Does anyone know where I can find a replacement? I tried Catalina direct to no avail. They suggested that I fabricate them. Problem is that I don't know the dimensions. Any suggestions would be welcome.
I may have a problem with my description of the part --- these are nylon donuts that could also doble as spacers that rest on top of the gudeons... approximately .75 inch by 1.25 inch in diameter... similar to a washer....
Then you are looking for common nylon washers. They can be found in any hardware or marine store. I think the earlier pintles were 3/8 but later Catalina switched to 1/2". Get the 1/2" (hole size) They will fit both pintles.
My gudgeons and pintles are a little worn, so they rattle around a bit. Is it possible to get a plastic sleeve to slip in between to fill the gap?, or am I best off replacing the whole kit?
Bruce, I had the same problem so I bought 2 brass bushings from Ace Hardware. They needed machining to fit but they work very well with very smooth rudder movement.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Thanks I think I'll have to stack them to get to my guess of 3/4 " thickness.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> If you have a 3/4" gap to fill it might be better to reset one of the pintles to the proper spacing. It sounds like they may have been adjusted to resolve a prior issue.
