I made a note of this in the C-25 forum discussing 3 gal tanks, but I thought I'd mention it here, too. Our Nissan 9.8 was not idling at all; it would stall. Someone said it was probably a clogged low idle jet and that the carb might need pulling, but to try a high concentration of Seafoam first. I put the entire pint into 2 gallons of fresh gas and ran that mixture at medium RPM's at the dock and took a few power rides over a period of about 3 weeks, while sailing and doing other projects on the boat. Coming back from a sail this past Saturday, I noticed that the motor did not stall out when I throttled back entering the docks, and it idled while we put the boat away. Yesterday, it was idling just as nice as you please. I haven't checked the tank with Seafoam yet, but I suspect that I may have burned less than a gallon of the treated gas. I'm thrilled that it worked and I do not have to remove the motor or haul the boat to remove the carb. Seafoam is a great product!!!!!!
DavidP 1975 C-22 SK #5459 "Shadowfax" Fleet 52 PO of 1984 C-25 SK/TR #4142 "Recess" Percy Priest Yacht Club, Hamilton Creek Marina, Nashville, TN
I am glad the Seafoam worked. I purchased some but never put it in the tank. Keep this in mind, If you do need to pull the carb, you do not need to remove the motor or haul the boat. It literally has only two bolts holding it in place.
Agreed, my Tohatsu only has two bolts holding the carburetor on. If I backed the boat up to the dock, it'd be pretty easy to remove sitting on the dock. Admittedly, I'd rather do this while on the trailer because Neptune's greed doesn't extend inland beyond the shoreline so dropped parts can be retrieved.
I did exactly this last weekend (instead of launching the boat), and it was a lot less of a job than I expected it to be.
And I'll be picking up a can of Sea Foam to put in my little 3 gallon tank, it's idling kind of rough.
All of the "mechanic in a can" products will work fairly well with deposits light enough that your engine is rough but still runs; you might try a shot every Spring and a spray carb/throttle plate cleaner in the Fall with the engine running as a maintenance procedure.
I was lucky this time, I guess. good to know that it is only 2 bolts holding it on, but with my usual luck, I would drop one in the water. What really pushed me to try the stuff was that the motor ran great given a bit of throttle, it just wouldn't idle at all. I figured I'd try the stuff and if it didn't work, I would pull the carb. I had even bought a spare low idle jet to be ready.
