My boat did not have a boomvang and after posting a question about boomvangs on the forum I decided to install one. All went well and it looked great. That is, it looked great until I tried to raise the poptop! So maybe THAT'S why the PO didn't have a boomvang installed. Fortunately, just loosening the sheets on it allows the poptop to be raised. I think that this is just another example of why you should sit and think for about half an hour before you do anything to your boat!
You did the right thing--it's a small price to pay for a useful control. Most of us recommend against sailing with the pop-top up, so you aren't missing anything. Another option is to use a snap-shackle on one end (a <i>good</i> one). (Be glad you didn't impulsively buy a rigid vang!)
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by John Russell</i> <br />Use the snap shackle and the boom vang can act like a preventer while running downwind.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...except that a vang is particularly valuable as a vang when running downwind--especially on a C-25 with its end-boom sheeting. (Besides, for a couple of reasons I won't argue here, I'm not a fan of preventers, unless they're rigged to be released very quickly from the cockpit.)
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dlucier</i> <br />Yeah, use a snap shackle at the mast end. Also, I flipped my vang so that it adjusts at the boom end. Makes things easier.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...unless you lead it back to a clutch on the cabin-top. Then you can adjust it regardless of where the boom happens to be.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Stinkpotter</i> <br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dlucier</i> <br />Yeah, use a snap shackle at the mast end. Also, I flipped my vang so that it adjusts at the boom end. Makes things easier.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...unless you lead it back to a clutch on the cabin-top. Then you can adjust it regardless of where the boom happens to be. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Dave, enlighten me. Why the hate for preventers? I am a big fan of them. I find that pulling teh boom forward and down, tying it off to the bow pulpit can give me a heck of a boost downwind in light air.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Prospector</i> <br />Dave, enlighten me. Why the hate for preventers?... I find that pulling teh boom forward and down, tying it off to the bow pulpit can give me a heck of a boost downwind in light air.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">First, I didn't race my C-25. Second, I generally thought of preventers as being safety measures for heavier air--not as a shaping device for light air. You're using it more like a "twing". My problem with preventers is the possibility of moderate-to-strong wind backwinding the main and creating an emergency. By definition, a preventer is for sailing in a situation where the sail might be backwinded--to "prevent" a violent jibe. I just avoid sailing that way, and if I suspect something, I jibe the main in advance and/or sail higher on a broad reach.
A vang will hold the boom down. If you're using a preventer to do it, you're adding strain to the preventer that could make releasing it all the harder (speaking of relatively strong wind). If you can't release it immediately, the boat could scream to a stop, loose all steerage, and broach. At that point, the strain on the preventer will likely make it impossible to release. To me, it just ain't natural.
If I wanted to do long dead-downwind runs without fear of violent, surprise jibes, I'd get a boom-brake. But again, I wasn't thinking about racing in light air with crew on the foredeck. I daysailed and cruised with passengers in the cockpit.
I agree with Dave regarding the use of preventers. I don't like sailing in strong, shifty winds with a sail "strapped down" in a way that can't be instantly released if necessary to keep the boat in control. When you're sailing in big winds, you always want to be able to quickly release your sail controls, in case the boat becomes overpowered. For example, when sailing to windward in big winds, you always keep the mainsheet in your hand, so that, if the boat begins to heel excessively, you can dump the mainsheet quickly. The principle is the same with a preventer, except it is attached well forward of the cockpit, where you can't release it quickly or easily, and the boat might broach before you can release the preventer.
You have a number of alternatives to using a preventer in big winds. On a long downwind run, you can bring the mainsail down and run downwind on the jib alone. That eliminates any need for a preventer. If you have a good helmsman, another alternative is to use a boom brake, and for crew to keep their heads down at all times while the helmsman minds the boat's angle to the wind closely so the boat doesn't gybe. Another alternative is to find a slightly different course, such as alternate broad reaches, so that you can sail downwind without risk of gybing. I don't say never use a preventer. I would be more inclined to use a preventer on a long run than a short one. My belief is that, because you can't release it quickly if necessary, it should be a last resort, used only when all alternatives are unsatisfactory. I don't like sailing a boat that I can't control at all times.
I have no reservations about using a preventer in light to moderate winds, to keep the boom from swinging back and forth when the wind isn't strong enough to hold it over on the leeward side. In that case, you don't need a preventer with mechanical advantage, so I like to rig a simple preventer with a piece of line attached approximately mid-boom and tied to a shroud with a slip knot, and with the tail of the line led to the cockpit. If you want to gybe, all you need do is tug on the line, and the boom will be free to swing across.
That makes three of us... I was delivering a Pacific Seacraft 37 to Maine with the owner. We were running downwind in heavy seas and he decided to show me how he could rig a preventer to port and run a staysail to starboard. I didn't object, but then we almost? ran over a shoal and we had to turn to port quickly. (The owner plotted the course - @##!&&^^%$&!!!!! - ultimately my fault anyway) The main backwinded and the boat heeled hard, I thought she'd roll. I was praying a line would snap. Boom brakes/preventers run from the cockpit - ok in heavy winds. Preventers on a C25 in heavy winds sounds like a very bad idea.
I also use a snap shackle at the mast end of my boom Vang. I also use it as a "preventer" downwind. But... I only use it in light to very moderate winds and, if I even "think" about danger, I release it. You have to use some common sense but in light winds it sure does help.
I would never use it in heavy winds. Too much can go wrong too fast. I should note that I don't race. Racing may be a totally different set of issues.
The snap shackle just gives so many options.
1. You can release the BV when the pop-top is up. 2. Preventer in light downwind (and spacious) runs. 3. You can release and tuck the boom vang under the sail cover if you want.
As usual, probably no wrong answer? Whatever you feel like...
If I don't say it enough... This is what's so good about this active forum. You hear options and ideas that you can choose to use or not. If your choice doesn't work you can search and find other options that you probably should have used.
Great discussion about vangs and preventers. I am learning lots.
Another point... in anything stronger than light winds dead downwind is not your fastest course. So not only are you potentially courting danger by using a preventer in strong air but you are also not sailing efficiently. For light air cruising it's a lot of fun to wing and wing, and impresses the guests.
Perhaps the only time I would use a preventer in big wind would be when racing, with enough skilled crew to tend it, and when maximum speed is essential. When you're shorthanded or not racing, there isn't enough of a reason to use one, and you don't have the necessary crew. One of the alternatives would be a better choice.
Like Calden, I love to sail wing-and-wing. It's the prettiest point of sail, and, in a gust, you really feel the full power of the wind.
I have actually toyed with teh idea of attaching a "stanction base sheave" (whatever teh proper name for them is) on either side of the pulpit to run a line from the docking cleat in the cockpit, forward to the bow pulpit, then back to teh boom as a preventer line.
In the case of the main getting backwinded, my preventer does its job, but if I need to release it quick, its easy to undo the cleat. Foredeck could rig the preventer in seconds, and when its time to gybe, it would be quick enough to release the line. pull it up on the foredeck, swing the boom across and rerig on the opposite side.
Since the main is alway on the opposite side to teh genoa, the cleat should always be available. I rarely cross-sheet downwind.
In an unexpected gybe, I have never had concern with broaching. I don't see a need for a preventer in heavy wind since I just adjust my course for the wind. A light hand on the tiller is key in shifty, strong winds. If you try to muscle the boat for the wind, you get in trouble quick. The toughest part in heavy wind that is inconsistent is neutral helm at the top of waves, and then you are best to fall off a little and bring the jib around to try reaching for a bit until either the wind or waves get steadier.
If the wind climbs, and I am caught with a preventer rigged in stronger wind than I want, then its fall off onto a reach, letting the extended main dump wind for a bit. Tie off the tiller, run forward and release the preventer, run back to the cockpit to sheet in the main, then remove the preventer line from the boom.
The only casualty I have suffered while doing this was last season when the whisker pole decided to wrap itself around the forestay while flailing from the end of teh jib. That was... uncomfortable.
Anyone have a whiskerpole they want to trade for a customized version?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Prospector</i> <br />Anyone have a whiskerpole they want to trade for a customized version? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> I have one, but it's resting 30' down, on the bottom of Brookville Lake. It sounds like we have the makings of an even trade!
