Anyone have this Tohatsu 9.8 "problem": motoring back to the marina the red oil warning light flashed on. I reduced speed and got back to the slip and killed the motor. The Manual says the red light means I have an oil pump switch problem. I checked the oil level; right to the top. I did my usual flushing routine in a bucket of fresh water and the red light didn't come on, even when I increased the rpm's. Maybe the light means I'm about to have an oil pump switch problem. Any ideas?
Never heard of an "oil pump switch". That light should indicate you have an oil <i>pressure</i> problem, although it could be that the <i>oil pressure</i> switch (that goes on if the pressure drops) is faulty. In other words, it's either the sensed or the sensor.
BTW, on a Honda outboard I once had, I got an audible alarm and check-engine light... It turned out to be a slightly corroded <i>battery cable hookup</i>.
My oil level was too high so I pumped some out and fired up the engine: no red light on. Apparently there's a pressure problem if the oil level is either too low or too high. Mine was too high.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by AADIVER</i> <br />My oil level was too high...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I've heard that this can be caused by gasoline blowing by the pistons into the sump, diluting the oil and increasing its level. I'd suggest changing the oil (so you know you don't have dilution), recording the precise level, and then checking it periodically to see if it's increasing. I don't know whether dilution might cause a low pressure reading, but most engine makers strongly recommend against over-filling with oil.
Frank, Dave brings up a good point. Hey, did you recently change the oil yourself or have it serviced? If not, they may be worth keeping an eye out if the level increases, once you removed to correct level. Keep us posted. Steve A
Yeah, it was too full. I just had it serviced and she runs like the proverbial top. Leaving for a cruise from Long Beach to Newport tomorrow, high pressure, light to nothing winds, so it may be a motor boat trip down and back on Sunday. Now if that oil light comes on...switch to a Honda ;-) ?
Steve, I didn't check my last post til today, sorry. The cruise was our annual to the American Legion Yacht Club, a couple miles west of the Newport Yacht Club. They gave me a slip. Engine worked fine since the tune-up.
Frank, sorry I missed you as well. There is next year! I have been to the ALYC on many occasions. Great place. How was sailing. Did you sail in the harbor or outside only? Steve A
