I'm replacing the masthead sheaves but they are not wide enough and leave a gap that the wire could easily fit in. Is there supposed to be some sort of washer between the sheaves to prevent that? The ones I removed were two different widths but one of them looked to be something someone picked up at a hardware store. It only has a diameter of 1.45 inches but it was .60 wide. The regular sheave is a 2" diameter and .40 wide. Doing the math, if I use the two regular sheaves, I'll have a .20 inch gap between them. Any ideas?
Ed HisHorse 1979 SR/SK #1393 Green Cove Springs, FL
I wonder if the sheave was replaced with a wider one to accomodate a change from wire to rope halyard. Be sure to replace them with sheaves of sufficient size to properly accomodate the lines running through them.
As for the gap, I'd use nylon washers to limit corrosion.
If you are replacing sheaves, I highly recommend that you consider changing to all rope halyards. Even with the divider plate in place, a wire halyard can jump a sheave and get stuck. Not good when the main is half way hoisted (don't ask me how I know this!)
My wire halyard did not cross over the partition, it wedged in between the partition and the sheave, too much slack in the halyard while raising the main.
I made my own partition out of aluminum plate and shaped it so that the wire can't possibly cross over. It extends up into the opening at the top of the masthead and fits all the way to the masthead and the plate was sized to leave no room for the wire to slip between the plate and the sheave.I will (in the future) move to internal rope but not quite yet. Actually. I believe that the two sheaves that were .60 inches wide were for rope halyards. I wonder if I can sell my redesign to Catalina? Anyway, I was doing some long needed maintenance which included replacing the anchor light and steaming light, adding a deck light and replacing the mast wiring and deck connector and part of it was the sheaves.
Another vote for all rope (low stretch), which in turn means different sheaves. 5/16' is common, and CD has the sheaves for that. Mine weren't internal--not as elegant, but fully adequate. I made the change when I was setting up to lead the main halyard back to the cockpit--also a nice upgrade.
I try to post a lot of images as I'm a photog and it's easy for me. I feel embarassed you think I'm blowin my horn, but some will see something that helps them, and me. I'm hoping to get the mast worked over this year, so I'm also following any mast threads. Following and trying to wait for a good LED external lighting solution.
It is fun to see Ed's work, a mechanic I believe. Talk about a get her done attitude and capability. Inspires me.
After my wire halyard jumped the sheave, I bought a plastic "For Sale" sign at Wal-Mart and cut a couple of disks the same size as the sheave, and put the disks between the sheaves, to take up the space. I never had a repeat of the problem.
Yeah redeye pictures are great. I figured posting them would be helpful as not many people have an up close visual of what is up there. I am learning a ton with mah new boat, went for a cruise Sunday and used the dinghy to go ashore for the 1st time. Good fun.
