 FRP failure on WK
Dan Lamb
Initially Posted - 05/17/2010 :  07:27:58  Show Profile
When I had the pre-purchase survey completed the surveyor indicated the FRP on the keel had some cracks and the sounding also showed signs of a bonding failure. After I pulled her out of the water last fall it was missing large chunks of the FRP coating. Has anyone had this problem and if so what is the best fix? I'm leaning toward using the West System and adding some filler to transition from the bonded surface to the raw lead surface. Since I will be doing all the work outside in spring temps I'm going to make an enclosure out of clear plastic and apply some heat overnight so it will get a good cure. Any thoughts or suggestions would be much appreciated.
Response Posted - 05/17/2010 :  18:04:26  Show Profile
Your best adhesion is with unfilled epoxy, so I'd go with that directly against the lead. After a couple coats as bonding layer, you can use the filled stuff to build up the coating thickness, or even better, lay cloth with unfilled epoxy. Do everything wet on wet to ensure good intercoat adhesion, unless heat builds up too much. If that happens you need to let the exotherm pass before doing the next coat.
Dan Lamb
Response Posted - 05/17/2010 :  20:35:01  Show Profile
Thanks for the input Rick. I think you're probably on the money regarding the first few coats being just the epoxy. That makes sense, but I don't think there is any fiberglass cloth on the keel, but it sure would build up the mill thickness pretty quick.
Response Posted - 05/18/2010 :  08:12:41  Show Profile
OK, I'll bit. What's FRP?
Response Posted - 05/18/2010 :  08:26:21  Show Profile
<br />OK, I'll bit. What's FRP?
Fiber reinforced plastic (fiberglass)
Dan Lamb
Response Posted - 05/18/2010 :  10:31:45  Show Profile
Actually the surveyor misstated the material....sort of. FRP stands for Fiberglass reinforced panel and is made by Marlite for typical commercial applications in bathrooms, kitchens, etc. It is easily cleaned and health departments love the stuff. My keel most likely has several coatings of epoxy or gelcoat possibly with fiberglass fabric wetted in and then is coated with the bottom paint so the surveyor was sort of correct, but in the construction industry FRP isn't epoxy built up on a keel. Last fall when I pulled the boat out of the water I was at the mercy of a friend with his GMC diesel truck and his two kids who weren't real happy to be demasting and and pulling a boat into storage for the winter so I didn't get a good opportunity to really check it out. I think I may contact Catalina and find out how they actually finish the keel on a 250. I'll be pulling it out of the storage building this Sunday so I'll get a much better look at the problem.
pa-sailor
Response Posted - 05/18/2010 :  15:36:16  Show Profile
My WK has some trailer nicks, but I didn't think any big deal since I sail in fresh water lake. Should I be concerned about repairing?
Dan Lamb
Response Posted - 05/18/2010 :  16:32:27  Show Profile
The ones I had weren't nicks from hitting anything. They were obviously from a failure in the material, failure of the application, or both. There could have been something on the lead keel that didn't get cleaned off prior to the coating being applied. Coming from Catalina with their excellent QC I was somewhat surprised by the failure. Your situation sounds like all you would have to do is do a little sanding prep and apply some epoxy resin to seal it back up. Mine is a little more severe. I have big areas of lead keel showing and it really needs to be sealed so I don't start getting water penetration under the gelcoat.
Response Posted - 05/18/2010 :  17:31:32  Show Profile
[url="http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=11249&catalogId=10001&langId=-1&storeId=11151&storeNum=10104&subdeptNum=10296&classNum=10300"]Marine Tex[/url] is a great product for filling in those little dings.
Dan Lamb
Response Posted - 05/19/2010 :  18:00:33  Show Profile
Thanks to all who commented. I received the repair instructions from Catalina today and here is what they say, and I quote "Using 80 grit sandpaper, grind around the repair to make sure you have eliminated any loose material that may still be there. Still using 80 grit sandpaper, sand entire repair area to assure good bonding. Clean the surface with acetone. Use either an epoxy fairing compound, or mix epoxy and cabosil to make a fairing compound in order to fill in any depressions where the old material released. Sand that epoxy mixture to fair the surface of the keel. Clean the surface with acetone. Apply two coats of epoxy to repair surface. The next day, after the epoxy dries, sand the repair surface and apply bottom paint".
It all sounds pretty basic, but cabosil is foreign to me??
Response Posted - 05/19/2010 :  18:27:37  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dan Lamb</i>
<br />It all sounds pretty basic, but cabosil is foreign to me??
Cabosil is fumed silica made by Cabot Corporation. If you're buying 50 pound bags (like Catalina does) you buy one of the grades of Cabosil. If you're buying 50 grams like the rest of us, you buy one of the West System 400-series fillers.
It is possible that Cabosil is available in smaller quantities, but the West System is more readily available for boaters, and selected specifically to use with their epoxy products. But it probably is just repackaged Cabosil.
This link probably has more than you want to know:
http://www.cabot-corp.com/Silicas-And-Aluminas/Downloads/DL200901110522PM972/
Edited by - TakeFive on 05/19/2010 19:23:25
