 Where to find U-bolts for our trailers?
Initially Posted - 05/14/2010 :  09:26:12  Show Profile  Visit delliottg's Homepage
While trying to remove the keel guides so I can finish soda blasting the keel, I snapped the head off of the first U-bolt I tried to remove. Where can I find replacement U-bolts? The bolts that are on there are galvanized, but the nuts they used aren't, so even with good penetrating oil, they're difficult at best to remove. Do I just need to find a trailer place & they'll have them?
I'm borrowing an air gun from work to get the rest of them off with, my wrists are aching from last night's work. Does anyone know if the bolts on the guide boards are carriage bolts, or do they have nuts on the other side. I'm afraid I'm going to have to cut them all off to get the keel guides off, re-carpet the guides (or replace & re-carpet depending on how they look) and reattach them (with good bolts).
Anyone done this, advice is eagerly sought, I just want to be done with this project, hopefully this weekend.
David
C-250 Mainsheet Editor
Sirius Lepak
bear
Response Posted - 05/14/2010 :  10:25:42  Show Profile
I would think a well stocked hardware store. I take my keel guides off each fall and put them on in the spring,facilitates washing the bottom. On my trailrite there are nuts on the end of the bolts. They are carriage bolts and will turn on you if the wood around them is rotted. Can you wait until boat is off trailer, much easier job. The ones I couldn't remove I just ripped the boards off and replaced, no big deal, once boards are off.
Response Posted - 05/14/2010 :  11:02:26  Show Profile  Visit delliottg's Homepage
Thanks, I'll probably look into just replacing the guide boards, I think I already have enough outdoor carpet to wrap new ones with. That way I can just Sawzall the boards off, or at least the bolts so I can use the boards as templates for new ones.
Fortunately we've got a really good hardware store just a couple of miles away from where I work so I'll stop by there on my way home to look for the U-bolts I need.
Does anyone have their trailer handy and could tell me their dimensions? (length of bolt, width between heads, and bolt diameter)
Thanks!
bear
Response Posted - 05/14/2010 :  11:26:04  Show Profile
David, As I did I measured everything I could, take an old bolt with you. I think I did this with the boat off the trailer and just clamped the new boards on and picked up the holes, you will have to countersink the new bolt holes where the head goes in. I think I launched "Brandy" one year with out the keel boards even installed.
Response Posted - 05/14/2010 :  12:11:53  Show Profile  Visit delliottg's Homepage
Yeah, I tried last night to get one off, but gave up after my wrists started complaining (and they're still complaining, carpal tunnel sucks), so I've borrowed that impact wrench from work to get them off with. I was just hoping I could find the U-bolts & nuts over lunch.
Tradewind
Response Posted - 05/14/2010 :  19:50:21  Show Profile
There is a trailer shop less than 5 miles from me, they build new trailers and repair old, I saw a stack of U bolts there 2 days ago, different sizes, post the size you need and I'll check.
Response Posted - 05/15/2010 :  16:54:48  Show Profile  Visit delliottg's Homepage
Steve,
I may have to take you up on that. I tried half a dozen places today, and the closest I got was Napa Auto Parts.
The good news is, with the impact wrench, I had all of the rest of the bolts off in less than 10 minutes. One of those is in my future, my wrists didn't even cringe, incredible.
I bought some composite decking 2x6's to replace the keel guides with, figure if I'm going to replace the, might as well make it so I never have to again.
Response Posted - 05/15/2010 :  21:31:51  Show Profile  Visit delliottg's Homepage
OK, now I'm officially irritated with Trailrite, or whoever put the keel guides on. They used carriage bolts hammered into the boards, that just spin when you try to undo them. Since they're rusted to the nuts, I have no choice but to cut them off. Hopefully it'll be easy to get behind them with my Sawzall.
At least I was able to get the guides away from the keel so I could get behind them to soda blast the last bits of paint off, so that's done. I also picked up two 5/4x6x12' Trex boards to replace the guides with.
I'm down to the last three pads, and beneath the keel, which I'm pretty sure simply isn't going to get cleaned or painted, at least not this year. I should get that done tomorrow.
Ed Cassidy
Response Posted - 05/16/2010 :  08:23:12  Show Profile
You might try a truck suspension shop for the 'U' bolts. I was out looking for a specific size and none of the trailer shops had them. The last place pointed me to a local truck shop and he took my rusted one and came back in 10 minutes with 4 new ones, made to order. And it only cost $9 each (in Stainless).
Tradewind
Response Posted - 05/16/2010 :  08:45:43  Show Profile
I also found large U bolts at a Tractor supply store.
jbkayaker
Response Posted - 05/16/2010 :  10:20:09  Show Profile
Here's a source for a couple of sizes:
http://www.pacifictrailers.com/index.cfm?fuseaction=catalog.catalog&catId=1766
Edited by - jbkayaker on 05/16/2010 10:23:22
Response Posted - 05/16/2010 :  12:14:08  Show Profile  Visit delliottg's Homepage
Pacific Trailer looked like a winner until their cheapest shipping was twice the price of a single bolt.
I think I've found a resource locally, but they're not open on the weekends.
Thanks for all the suggestions, I appreciate it.
