 VHF antenna placement
SRH_Catalina_Newbie
Initially Posted - 03/28/2010 :  19:19:15  Show Profile
Has anyone mounted a VHF antenna on the mast? It looks like the best place for the bracket is right on the side of the aluminum masthead but that is exactly where the directions from Cat Direct say not to install it.
My only alternative is mounting it to the side of the mast about two feet down from the top to avoid the main stay.
Any suggestions would be welcome.
Response Posted - 03/28/2010 :  20:18:42  Show Profile
Mine extends 8 feet above the mast. My kid fixes radios for Uncle Sam's Air Force and he said the higher the better and an 8' whip was my best choice.
SRH_Catalina_Newbie
Response Posted - 03/29/2010 :  04:14:36  Show Profile
Thanks John! Is it mounted to the mast or the mast head?
Response Posted - 03/29/2010 :  07:04:49  Show Profile
It's mounted on at the masthead next to the anchor light and above everything else. It's on a "tab" that extends a couple of inches from the masthead.
Even Chance
Response Posted - 03/29/2010 :  08:08:11  Show Profile
It's true that the higher the better -- VHF is line-of-sight. Most sailboats use the 3' base-loaded whip. I'm not an electronics expert, but my understanding is that one of the antenna issues on a sailboat is the relationship between the dB rating and angle of heel. The higher the dB rating -- I think the 8' antenna that is being recommended is higher dB than the 3' -- the more concentrated the output signal is. That means you can be heard farther because the beam is narrower. However, if your boat is heeling, the narrower signal may go up over your intended target.
My 3' whip at the masthead can hear 30 miles away (depending on the height of the transmitting antenna, of course), and I've been able to transmit and be heard by another sailboat 20 miles away, even with the boat heeling significantly.
Response Posted - 03/29/2010 :  09:13:04  Show Profile
Mine is mounted on a tab on the side if the masthead. I have a SS whip antenna. It is that round can looking thing ( the whip is removed in the photo) in the five o'clock position.
Response Posted - 03/29/2010 :  10:18:01  Show Profile  Visit OLarryR's Homepage
I was having an OGM LED Anchor Light installed and the brackets I had would not work for it. So, the mechanc that worked it for me had a shop make a stainless steel bracket with holes drilled for it and a tab coming off of it horizontally with a hole to attach the VHF antenna.
Response Posted - 03/29/2010 :  10:28:09  Show Profile
An 8' whip on the mast-head is overkill IMHO, given the weight and windage it adds up there. Most sailors are satisfied with a 3' base-loaded whip on the mast-head, or an 8' fiberglass whip on the sternrail (eliminating the issue of snaking coax through the mast). It's true that higher "gain" (measured in dBs) produces a flatter transmission pattern that could reduce range somewhat at substantial heel angles. And bigger whips have higher gain.
The USCG has an array of tall antennas along the coast, and high-powered transmitters. They can hear you, and you them, from a long way out even when you're just using a hand-held with a rubber-ducky antenna. They can also triangulate on your signal to estimate your position. And contrary to what "line-of-sight" might mean to some people, VHF waves do bend somewhat over the horizon as well as over land masses and tree lines, just as waves in water go around islands and points. VHF just doesn't bounce of the ionosphere as AM and SW signals do. I regularly communicate over a 40'+ high land mass from my 12' high (at the midpoint) whip to a pumpout boat in a cove several miles away.
Edited by - Dave Bristle on 03/29/2010 10:34:38
Response Posted - 03/29/2010 :  10:44:58  Show Profile  Visit OLarryR's Homepage
Forgot to mention that my antenna is one of those shorty ones...perhaps 1-2 ft max above the mast top.
Response Posted - 03/29/2010 :  13:09:10  Show Profile
I second Bristle, put a 3 footer at the masthead or an 8' whip on the rail. I have a 90ยบ bracket on the starboard side of the mast, not the masthead fitting; it doesn't matter which side its on as long as there is room.
Edited by - Dave5041 on 03/29/2010 13:12:49
SRH_Catalina_Newbie
Response Posted - 03/29/2010 :  20:35:07  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by islander</i>
<br />Mine is mounted on a tab on the side if the masthead. I have a SS whip antenna. It is that round can looking thing ( the whip is removed in the photo) in the five o'clock position.
Thanks for the picture that really helps. I have a 3 foot whip and a similar round can as a base. It looks like you were able to install it next to or just above the main stay and clearly it didn't get in the way lowering the mast. Big help, Thanks.
frog0911
Response Posted - 03/29/2010 :  21:15:05  Show Profile
More pictures:
SRH_Catalina_Newbie
Response Posted - 03/30/2010 :  13:34:26  Show Profile
I want to thank everyone for your input. I think I will go ahead and mount my 3' antenna to the mast head even though C-Direct instructed me not to.
This looks like the best solution and nobody who did it is complaining about the results.
Thanks again!
Response Posted - 03/30/2010 :  21:08:44  Show Profile
How will you do your deck fitting at the bottom of the mast? You should use a coaxial connector.
You have to make sure that the connector impedance (50 Ohms or 75 Ohms) matches the cable impedance.
Most boating stores and catalogs will carry them.
Response Posted - 03/30/2010 :  21:28:49  Show Profile
If you need details about the deck connector, you can find info in Don Casey's book "Sailboat Electrics Simplified". The coax connector is a critical component.
Response Posted - 03/31/2010 :  17:38:16  Show Profile
Here's a link for a thru cabin coax connector
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/19502/377%20710/0/coax%20connector/Primary%20Search/mode%20matchallpartial/0/0?N=377 710&Ne=0&Ntt=coax connector&Ntk=Primary Search&Ntx=mode matchallpartial&Nao=0&Ns=0&keyword=coax connector&isLTokenURL=true&storeNum=5003&subdeptNum=3&classNum=30
Here's one you can screw down in place
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/13552/377%20710/0/coax%20connector/Primary%20Search/mode%20matchallpartial/0/0?N=377 710&Ne=0&Ntt=coax connector&Ntk=Primary Search&Ntx=mode matchallpartial&Nao=0&Ns=0&keyword=coax connector&isLTokenURL=true&storeNum=5003&subdeptNum=3&classNum=30
SRH_Catalina_Newbie
Response Posted - 04/01/2010 :  08:28:16  Show Profile
Good question on the deck fittings and thanks for the links.
I bought the entire antenna kit from CD. I got the whole package from antenna, cable, fittings the works. The only thing that confused me was that they said specifically in the instructions NOT to mount the antenna to the mast head which is why I posted this Q to begin with.
This forum has been a fantastic resource for this rookie sailor. I will post pictures after I mount the antenna to the mast head and finish the job of running the antenna cable into the cabin.
Response Posted - 04/01/2010 :  09:02:17  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">The only thing that confused me was that they said specifically in the instructions NOT to mount the antenna to the mast head <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Perhaps they were indicating it should be mounted to the bracket and not directly to the mast head. According to there web site they say:
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Ours installs at the masthead exactly where you want it.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Classic doublespeak.
