 Another off-season thing to worry about!
hinmo
Initially Posted - 10/27/2009 :  16:49:59  Show Profile
In attempting to cover my boat for the off-season (cheaply I might add!) I tried to pull out the spreaders (mast laid on my deck) after removing the pins. They don't budge even with a vise-grip and some persuasion. So I took off the plate that holds them to the mast...all good.
Of course my friend (serious J-boat capt) said if the spreaders did not come out of the sockets/brackets, they must be corroded/seized in the sockets and they would be <u>PRONE TO BREAKING</u> under normal operating stress.
Is he right? Come-on...dont I have enough stuff to worry about?
thx
"Kukla" '83 FK,SR
Response Posted - 10/27/2009 :  17:01:48  Show Profile
Just like steel, aluminum does oxidize. I would certainly want to remove and inspect them . . . key piece of rigging!
Response Posted - 10/27/2009 :  17:49:34  Show Profile
He is right. Good chance they will fracture at the base, I would deal with it.
hinmo
Response Posted - 10/27/2009 :  17:59:05  Show Profile
Seriously - how many folks have checked theirs...and how many actually can remove them?
Tom Gauntt
Response Posted - 10/27/2009 :  19:01:40  Show Profile
I checked mine, found one bent, and a good bit of corrosion. Ordered replacements from CD and easily replaced both.
This is a "side-by-side" of a new spreader and the original.
Edited by - Tom Gauntt on 10/28/2009 06:28:07
hinmo
Response Posted - 10/27/2009 :  21:07:32  Show Profile
ok - here goes the off-season budget. Since they did not budge with a vise-grip and hammer, should I be soaking with WD in an attempt to dislodge?
Response Posted - 10/28/2009 :  00:07:09  Show Profile
BP Blaster works miracles on steel - I wonder how it might work on this application.
Tom Gauntt
Response Posted - 10/28/2009 :  06:20:54  Show Profile
hinmo,
Do you have the cast aluminum spreader brackets or the the stainless? If you have the cast aluminum, you should probably look at replacing those rather than wrestle the old spreaders out. If you have the aluminum, go ahead and replace the spreaders and brackets at the same time. The spreaders weren't that expensive from CD. I think the bracket is around $130 and the spreaders are about $30 each.
Response Posted - 10/28/2009 :  07:30:00  Show Profile  Visit aeckhart's Homepage
I remove my spreaders every season. It makes it much easier to work on the boat when the mast is down on deck and they won't interfere with the tarps and framing when the boat is covered.
Perhaps you already have the stainless sockets and galvanic action has caused the unlike metals to fuse together.
Renzo
Response Posted - 10/28/2009 :  08:05:09  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by hinmo</i>
<br />Seriously - how many folks have checked theirs...and how many actually can remove them?
Only those people who store with their mast down.
Response Posted - 10/28/2009 :  15:42:53  Show Profile
I was crewing on a C&C 38 out of Cleveland one summer when during a race the leeward spreader came off. We were so focused on the what was going on around us we didn't notice. Needless to say when we tacked - the mast snapped in two. The effort and cost of inspecting and possibly replacing the spreaders pales . . .
Edited by - OJ on 10/28/2009 15:43:32
hinmo
Response Posted - 10/28/2009 :  16:36:09  Show Profile
Yup - its now on my must do list:
1) new rudder ($700)
2) spreaders and brackets ($150)
3) Various standing rigging components ($200)
ARRRGGGHH - another grand!
Response Posted - 10/28/2009 :  18:42:16  Show Profile
B.O.A.T. = Break Out Another Thousand!
Are you sure you don't already have the stainless brackets? I thought the change was before 1983, but my memory should never be trusted! Actually, the stainless would better explain some corrosion--dissimilar metals.
Edited by - Dave Bristle on 10/28/2009 18:43:32
hinmo
Response Posted - 10/29/2009 :  00:28:50  Show Profile
D - pretty sure I do have ss brackets, but am anticipating issues getting the spreaders out and damaging the current ones. Maybe I can salvage.
pfduffy
Response Posted - 10/29/2009 :  07:11:15  Show Profile
I will be dropping my mast to store over the winter and I am adding spreaders to my list of things to check / repair. So my question is assuming that I have corrosion from the 25 years of dissimilar metals living next to each other, when I replace the spreaders, should I coat the end with tef-gel to prevent corrosion in the future or is that stuff only for threaded connections.
Response Posted - 10/29/2009 :  07:15:23  Show Profile
Yes (short and log answer)! I always do, and my spreaders sip out easily.
hinmo
Response Posted - 10/30/2009 :  17:57:44  Show Profile
Tried to get the spreaders off today, how do I get the spring clips off of the upper shrouds?
Edited by - hinmo on 10/31/2009 01:58:18
hinmo
Response Posted - 10/31/2009 :  09:13:45  Show Profile
Update - I just unwound them. Don't know how to replace them tho
Response Posted - 10/31/2009 :  13:16:24  Show Profile
<br />Update - I just unwound them. Don't know how to replace them tho
Well, hinmo, you are well on your way to becoming a Catalina 25 maintenace guru! As my father used to say - most things are much simpler than they first appear.
How do your spreader ends look compared to the photos posted my Tom Gauntt above?
Like you, I remove my spreaders to accomodate a winter tarp. Instead of dealing with the original pins that hold the spreaders in the sockets - I used stainless machine screws with locknuts . . . no more cotter pins to wrestle out.
Edited by - OJ on 10/31/2009 13:31:36
Deric
Response Posted - 10/31/2009 :  19:25:59  Show Profile
I would take the mast off the boat and store is in my garage suspended from the ceiling. I liked having the many months of winter to check the mast and all that is connected to it. I also would test lights, and retape, recaulk, typical maintenance stuff.
I would be nervous not knowing the condition of the spreaders.
Best,
Deric
hinmo
Response Posted - 11/01/2009 :  03:18:26  Show Profile
Ok folks, I AM replacing the spreaders, but not the brackets (if I get the old spreaders out clean).
QUESTION IS....how do I attach the spreaders to the shroud. They WERE attache with that little spring clip thing, that I had to unwind to get the spreader detached?
The spring think looks like it is wound on to the shroud wire with a tool. Is there an option?
Response Posted - 11/01/2009 :  07:26:48  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">[i]Is there an option?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">CD has a pair of leather [url="http://www.catalinadirect.com/index.cfm?fuseaction=product.display&Product_ID=1093"]spreader boots, [/url]that you could also make yourself, but WM sells the [url="http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/232539/377%20710/0/rigging%20tape/Primary%20Search/mode%20matchallpartial/0/0?N=377%20710&Ne=0&Ntt=rigging%20tape&Ntk=Primary%20Search&Ntx=mode%20matchallpartial&Nao=0&Ns=0&keyword=rigging%20tape&isLTokenURL=true&storeNum=175&subdeptNum=680&classNum=680"]rigging tape [/url]that I used.
Response Posted - 11/01/2009 :  10:16:05  Show Profile  Visit aeckhart's Homepage
Use stainless wire available at any hardware store. Run the wire through the hole in the spreader than wrap the two ends around the shroud - one end above and one below the spreader. Do not make this connection too tight. The shroud must have some play through the wire loops but must be held into the slotted spreader end cap. Once the wire is on add the spreader boot.
Response Posted - 11/01/2009 :  13:36:25  Show Profile
If you look at the Catalina 25 parts catalog, they don't have a part number for the "spring clip" which may imply (as aeckhart explains above) that you purchase a spool of stainless wire and re-wrap the stays to the spreader end caps. Wish I had a my boat nearby . . . I'd post a picture!
hinmo
Response Posted - 11/01/2009 :  17:08:46  Show Profile
I already removed them. I think I left the remainder of the spring clip (half unwound) on the shroud. I will try to photo. Guess I will have to do what Al said. It seems like the winding is very tight and must have been done by a tool, not by hand.
Response Posted - 11/01/2009 :  18:19:30  Show Profile
hinmo, there is a good likely-hood that a special rigging tool of sorts was used to wrap the wire you describe. This same wire was probably wrapped by someone who has done it a thousand or more times before. For us novices a pair of pliers or needle-nose and side-cutters may have to suffice.
Your post has motivated me to check the spreaders on the boat I recently purchased. A photo of this wire wrapping posted here would be very beneficial!
