 Bus Bar
jking
Initially Posted - 07/23/2009 :  22:05:02  Show Profile
Where is the bus bar (negative terminal) on the 250? I can't seem to locate mine, and it's not clearly stated in the manual.
John
250 WB #887
'Flying Wasp' , formerly 'MAD MOM'
Response Posted - 07/23/2009 :  22:26:48  Show Profile  Visit delliottg's Homepage
John,
The breaker panel is on the starboard side of the boat just aft of the galley (you almost certainly already know this, but just in case). Inside the panel are two bus bars for positive, and tucked up a bit further inside the hull and a bit further aft (less than six inches) is a negative bar epoxy bonded to the inside of the hull. At least that's how our '97 is done, yours is a newer boat, but I'd imagine it's basically the same.
KD4AO
Response Posted - 07/24/2009 :  05:58:03  Show Profile
Same on an '03. Not very big, 5 or 6 inches maybe.
Response Posted - 07/24/2009 :  07:22:01  Show Profile
Here it is:
Oh, I thought you wanted to know where the bar bus was!
jking
Response Posted - 07/29/2009 :  18:45:06  Show Profile
Thanks for the replies. I looked in that location tonight, and can't find it (I do know what it looks like, thanks to the WM catalog). Looks like a call to Frank Butler may be in order!
jking
Response Posted - 07/29/2009 :  18:50:37  Show Profile
bear
Response Posted - 07/29/2009 :  19:24:54  Show Profile
John, If you have an owners manual it may have a schematic showing where your grounds are. If not call Catalina engineering, even with my 95 model they have helped and didn't care the boat was over 10 years old. I might also suggest tracing the ground wires routing on the negative battery terminal and see where they end up....
Response Posted - 08/03/2009 :  20:04:31  Show Profile
I'd have second Bear's advice, follow the black wires back from the switch panel, lights, radio and the battery's negative terminal. The negative ground is never switched, so you will see all the ground-wire home-runs converging in one place - the bus bar.
And, of course, you'll see all the partiers converging on the bar bus! (thanks Randy!)
On my '85 C25, I had connection and voltage drop issues, so I entirely replaced the bus bars with industrial strength copper bus bars from a Square D 200 Amp commercial circuit breaker. I also installed heavier guage wire around the boat. No more voltage drops!
