 Is Catalyst for Gelcoat the same for Fiberglass?
Steve Blackburn
Initially Posted - 05/02/2009 :  13:27:55  Show Profile  Visit Steve Blackburn's Homepage
Anyone know if the catalyst used for Fiberglass can be used for Gelcoat? I couldn't find the catalyst bottle for my Gelcoat but found one in my fiberglass kit. Are they interchangable?
Steve Blackburn, Calgary, AB
C250WB - 1999 - Hull 396
Response Posted - 05/02/2009 :  14:24:30  Show Profile  Visit delliottg's Homepage
Steve, I don't believe they're the same.
Response Posted - 05/02/2009 :  14:45:31  Show Profile
I very seriously doubt epoxy and gelcoat catalysts are the same stuff. Polyester resin (now used in most boats) catalyst might be compatible with gelcoat.
Edited by - Dave Bristle on 05/02/2009 14:47:53
Steve Blackburn
Response Posted - 05/02/2009 :  16:20:19  Show Profile  Visit Steve Blackburn's Homepage
Well it has hardened so I guess its working. Dave why do you say epoxy? The fiberglass kit I have is normal resin is it not?
Tried to google this and didn't find anything.
The hardener says LIQUID HARDENER (MEKP).
"MEKP is composed of methyl ethyl ketone peroxide, a catalyst, added to polyester and vinyl resins.
When MEKP is mixed with the resin, the resulting chemical reaction causes heat to build up and cure or harden the resin."
OK I think I`m good, says that Polyester / Vinylester Gelcoats need MEKP hardener. Just lucky I guess.
Edited by - Steve Blackburn on 05/02/2009 16:25:54
Turk
Response Posted - 05/02/2009 :  19:37:35  Show Profile  Visit Turk's Homepage
Frank butler told me to go out and by fiberglass hardener for the gelcoat he sent me. He said any would do.
Response Posted - 05/02/2009 :  21:01:36  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Steve Blackburn</i>
<br />Dave why do you say epoxy? The fiberglass kit I have is normal resin is it not?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">You didn't say, and there are two basic types. Many people do fiberglass repairs with epoxy resin and glass cloth, so I just suggested the distinction, which I still believe involves different hardeners. Some substantially more expensive boats are built with epoxy resin--most these days are built with the cheaper (and less strong) polyester resin.
Response Posted - 05/05/2009 :  07:35:48  Show Profile
If you just go down to the hardware store and buy fiberglass resin it will most likely be polyester resin. West Systems product is epoxy resin and is a much stronger and harder solution. Polyester resin may chip or break under stress. Epoxy resin is better suited for those situations.
