 mercury outboard queston
quilombo
Initially Posted - 06/16/2008 :  19:48:28  Show Profile
anybody out there ever change an impeller on a mariner 9.9 89 90 vintage
JimB517
Response Posted - 06/17/2008 :  00:30:12  Show Profile  Visit JimB517's Homepage
No, but they are all about the same. You have to remove the lower end oil, drop the lower end. You have to disconnect the shift linkage. You need the new impeller and all the gaskets.
For a guy like you, should be easy. You can get a shop manual on the web.
Stardog
Response Posted - 06/17/2008 :  12:01:43  Show Profile
I used to do it on my old Suzuki, it's surprisingly easy and it only took me about 1/2 hour from start to ready-to-be-remounted. Just make sure to follow instructions and replace anything they say to replace, refill with new oil, etc. Then you won't have to worry about bottom-end maintenance for a long time.
