I want to get a whisker pole for my 2004 Catalina 250WB. Foresparhas a model that is 1-1/4" o.d., adjustable from 6' to 12'. Will this model work for my boat? This model is around $130 and to go heavier would cost almost three times as much. Also, do I need a whisker pole with latch & spike ends, or with latch & latch ends? Thanks - Roger
According to Forespar you should use the HD 6-12. The SDJ 6-12 that you mention is not heavy-duty enough and will not be strong enough at the length you will need to extend too. I have the HD 6-12 and it works fine. It has the latches at both ends.
There are significant forces on a whisker pole and going too light could damage the pole and create problems for you. They are expensive pieces of gear.
Before buying your pole, it may be wise to check how much distance is between the grommet at the clew of your jib and the edge of the sail. I wanted a latch on both ends of my whisker pole, and bought it that way, only to find out that the latch was not large enough to snap into the grommet. The problem was easily solved by tying a loop of line through the grommet and attaching the latch through the line loop, but its probably not ideal.
Randy! Am I missing something...the latch goes over the sheet? If I had the pole with the spike rather than the the latch how would that work? Feeling a bit dumb here... Willy
If you had a pole with a spike then it would go through the grommet. But my experience with a whisker pole is similar to using a spinnaker pole. The latch latches over the sheet. When the sheet is pulled tight that will keep the pole at the sail corner.
Here is a what Forespar says "When you decide to set the pole and bring the jib across to windward, put the lazy jib sheet into the outboard pole fitting, extend the pole and attach to the mast fitting."
HOWEVER - they also later say: The whole procedure can be simplified by having a small vinyl coated wire loop installed in the jib cringle to which the pole can be attached...."
So, both ways are OK! Thanks for the question, it made me research more. I crew on a Santana 20 racer and I attach the whisker pole the same way I attach the spinnaker pole on the racer. I learned something today!
I'm about to buy a new 135% genoa and a Forespar HD 6-12 whisker pole as recommended here. However when the time comes to buy a symmetrical Spinnaker will I be able to use the same whisker pole or do I need to buy a spinnaker pole for some reason? I don't understand the differences.
From looking at them it seems that the spin pole has a toping lift as well as a vang to keep it down. Is that the only difference? At over $300 I really want to buy only 1 good pole that could for both.
A friend of mine lashes a stainless steel ring to the clew on the leech side of their C-22 genoa, then attaches the pole to the ring. I've used a small loop made of 1/4" line which works fairly well, but the knot can come undone. If you use a single jib sheet line looped through the clew, try tying a second knot about 4" from the clew. Then you can attach the pole to the sheets between the 2 knots and the knots will keep the pole in place. The advantage I see to these methods as opposed to hooking the pole over the loaded sheet is that you can then gybe the genoa without having to release the pole from the clew.
Paul, I have seen this done. They simple unclip the pole from the mast ring prior to the gybe, help the sail to the other side and reclip to the mast ring.
Locally there is a pole for sale - 13 ft long and 3.5" thick, would it be worth it to cut down something like that to size? If so, I wil lsee if it is available for other folks who may be interested (I don't think I need it)
Our routine with the whisker pole is to attach it to the bowline on our jibsheet, then clip the end of the pole that telescopes to the ring on the mast. We generally do this as we round the jybe mark. Then we extend the pole (telescopic), tie a preventer forward off the boom (use a quick release rolling hitch), and foredeck goes to lean on the boom holding it as far forward as possible. The whole routine takes something like a minute and a half, unless something goes really wrong. Our biggest challenge is that we have a lot of pole, but no topping lift. I need to rectify that for next season.
Paul, If you want to leave the pole attached to the clew in a gybe, here's how. After the command to gybe is given and the main is moved over to the other side, the jib/genoa sheet is released and the foredeck person removes the pole from the mast ring. The mast end of the pole is immediately raised upward in front of and along the mast and the pole is used like a broom handle to sweep the clew across the boat and out to the other side. The mast end of the pole then comes down and is reconnected to the mast ring. It's very fast. I've done this with a fully extended HD6-12 without collapsing the pole. The longer HD7-17 pole will most likely need to be collapsed (1 section) before disconnecting from the mast. We use this method on the C-22 all the time and have adapted it to the C-25.
Steve, spinnaker poles and whisker poles are not alike. A spinnaker pole is fixed in length, usually limited to the J dimension (distance from base of mast to forestay at bow), and has topping lift and downhaul bridles, and a whisker pole is generally adjustable and longer, especially if you want to pole out a 150 genoa, and does not have the topping lift or downhaul. The HD6-12 is fine for the 110 and maybe the 135, but it is really too short for the 150. A spinnaker pole would be long enough to pole out a 110.
